Monty wrote:Any chance of a price on the Basic kit? as i'm getting low on funds so i may have to go down this route
ailwyn wrote:BASIC KIT $556
1)
2)
ADVANCED KIT $1052
1) Monty 2.5" inlet, Blue Connectors. Downpipe Jet Hot coated and turbo gaskets plz
2) MattDon red connectors
3) Ailwyn 2.5", black connectors
4) Nige 2.5" inlet, Red Connectors. Downpipe Jet Hot coated and turbo gaskets please.
STAGE ONE GT2554 KIT $1976.38
1)
STAGE ONE GT2560 KIT $1976.38
1. Ailwyn 2.5", black connectors, Jet hot coated Downpipe. Polished turbo ( if possible) Delivery UK. 12psi wastegate.
2. Paul.P - 2.5" inlet, Black connectors. Jet hot coated downpipe. Polished turbo ( if poss ) 12psi wastegate
3. Dico - 2.5" inlet, Blue Connectors. Jet hot coated downpipe and heat shield. Polished turbo (if possible) 12 psi wastgate
4 Richard K -, 2.5" inlet, Black Connectors. Jet hot coated Downpipe. Polished turbo ( if possible) Delivery UK. 12psi wastegate.
5. MattRI - 3" inlet, Yellow or green Connectors preferred, if not available- Black. Jet hot coated downpipe and heatshield. Polished turbo (if possible) 12psi wastegate
6. A B Munro - 2.5" inlet, Blue Connectors. Jet hot coated downpipe. Polished turbo (if possible)Delivery UK. 12psi wastegate.
Paul.P wrote:Hi Marie, me & Dico we're talking & just wondered if you could clarify something for us, are you running your engine with the 550 injectors, 3 bar map sensor, & the standard ECU with a MBC, & NOT using a different chip ( ESM or other ), it appears that way from your project thread ?. Also, i see Ekapol has a one off chip from ESM which he runs in conjuntion with the everest chip, is this the sort of chip we're asking Alan to replicate as a group buy ?.
Sorry for all the questions, just trying to understand it all![]()
Many thanks, Paul.P
Ekapol wrote:Sorry for the delay, schedule has been being very tight. I've added the price for the BASIC KIT below:
Downpipe only is $345
BASIC KIT $556
1)
2)
Monty wrote: which would mean the oil/water lines are costing $211? as that seems alot for the linesHow many lines are there?
Parts for Basic Kit:
AER-FBM1003
Hose Clamp, Pro Clamp, -8 AN, Steel, Red Anodized Aluminum Cover, .440 in. Maximum Diameter, Each
$6.50
$13.00
AER-FBM1031
Fitting, Hose End, AQP Hose, 90 Degree, -4 AN Hose to Female -4 AN, Steel, Red, Each
$19.95
$39.90
AER-FBM2006
Fitting, Straight, -8 AN Male to 1/4 in. NPT Male, Aluminum, Blue, Each
$6.50
$13.00
AER-FBM2948
Fittings, Brake, Steel, Zinc Plated, Male -4 AN to Banjo 10mm, Pair
$29.69
$29.69
AER-FBM4023
Fitting, Hose End, AQP Hose, 45 Degree, -8 AN Hose to Female -8 AN, Aluminum, Red/Blue, Each
$23.95
$23.95
AER-FBM4033
Fitting, Hose End, AQP/Starlite Hose, 90 Degree, -8 AN Hose to Female -8 AN, Aluminum, Red/Blue, Each
$23.95
$23.95
AER-FCA0403
Hose, AQP, Braided Stainless Steel, -4 AN, 3 ft. Length, Each
$16.95
$16.95
AER-FCA0803
Hose, AQP, Braided Stainless Steel, -8 AN, 3 ft. Length, Each
$21.95
$21.95
