by Matt RI » Tue 29.09.2009, 04:26
Ditto, Tigerdog...
1. Elanlover
2. superbad
3. lotos
4. cliffyg
5. Tigerdog
6. Matt RI
I like traffic lights. But only when they're green...
Matt RI
by Elanlover » Tue 27.10.2009, 21:06
by superbad » Sun 01.11.2009, 17:07
Goodbye Pontiac wheel. Nice work both of you!
(Next step is to make a new round steering column shroud...)
superbad
by Elanlover » Mon 02.11.2009, 18:51
Changes communicated to Bob who will begin working on a mkII version to test as time permits. I never thought to do this but I will reinstall the Elise wheel and take the car out for run around the block then post back how the car feels with going to the smaller Elise wheel.
by lotos » Mon 02.11.2009, 21:13
Great work! Please do let us know how it feels with the Elise wheel!
Also when are you going to start on that fascia for a group buy???
lotos
by gomper71 » Tue 03.11.2009, 01:27
If the cost is $100 or less for an adapter for a Elise wheel with airbag, I would be interested in one of these. Is this list still open? I had not considered doing this change but it looks good and if it gives more leg room I could use that. I hate to pass on group buys because they may not come around again any time soon or at all.
Tom-'91 Red M100
gomper71
by Elanlover » Tue 03.11.2009, 01:54
Still open - just add your name to the list
by gomper71 » Tue 03.11.2009, 23:27
1. Elanlover
2. superbad
3. lotos
4. cliffyg
5. Tigerdog
6. Matt RI
7. gomper71
Tom-'91 Red M100
gomper71
by Elanlover » Mon 09.11.2009, 22:58
Sooooo..............the little test run around the block was interesting.
I like the smaller steering wheel. It really does feel more like a sports car with the smaller wheel instead of a Lincoln land yacht with that truck wheel. The smaller diameter wheel means the steering is stiffer. Now, when I put the 17" wheels on the car the steering became "looser' than stock. The combination of the 17" wheels and smaller steering wheel return the car to about the stiffness of stock for me - with the added benefit of a better looking and feeling steering wheel. Those with the stock wheels will likely feel the steerign getting a bit stiffer but I can't see it being so noticeable as to be a pain.
Once the mkII hub is fitted I'll work out the details on the airbag and horn connections which are different. It will invlove sniping the leads from the stock setup and attaching those from the Elise setup.
by lotusgirlmarie » Tue 10.11.2009, 00:01
Just curious but would the new adapter plate fit inside the wheel? This would give it a cleaner look I think. Just curious.
lotusgirlmarie
- Goddess
by superbad » Tue 10.11.2009, 01:33
Elanlover wrote:Now, when I put the 17" wheels on the car the steering became "looser' than stock.
Different offset on the 17s? If so, it would have given you a smaller scrub radius which would explain the reduced steering effort.
Also, anyone have an Elise wheel they want to sell? I know there's at least one on Ebay, but I'd rather get one from LEC if that's an option.
superbad
by Elanlover » Tue 10.11.2009, 01:59
lotusgirlmarie wrote:Just curious but would the new adapter plate fit inside the wheel? This would give it a cleaner look I think. Just curious.
Unfortunately no, there's not enough room for the airbag module. The splined section needs to be a specific length and the airbag module is only about 10mm (can't remember exactly) from the bottom of the inside of the wheel. Its a nice idea though which would push the wheel further away from the driver a bit more but its not possible.
by Elanlover » Tue 10.11.2009, 02:01
superbad wrote:Different offset on the 17s? If so, it would have given you a smaller scrub radius which would explain the reduced steering effort.
Same +60 offset as stock.
I do have an extra wheel and a contact ring (which you'll need). I paid $300 USD for the wheel (near new condition) and $50 for the contact ring. In fact, its the wheel shown in the pics above.
by superbad » Tue 10.11.2009, 16:21
Elanlover wrote:I do have an extra wheel and a contact ring (which you'll need). I paid $300 USD for the wheel (near new condition) and $50 for the contact ring. In fact, its the wheel shown in the pics above.
Mark me down for that one. Thanks!
superbad
by Elanlover » Tue 10.11.2009, 16:32
superbad wrote:Mark me down for that one. Thanks!
Done. Keep in mind that you'll need an airbag too. Prices vary for that and I'd start searching eBay for one as they come up from time to time (that's where I got mine from). You can PM your address details to me and we'll sortit all out when the hub's been finalized.
by lotos » Tue 10.11.2009, 17:24
Is that the same one you promised to me in Feb or do you have 2 extra?
lotos
by Elanlover » Tue 10.11.2009, 19:23
lotos wrote:Is that the same one you promised to me in Feb or do you have 2 extra?
DOH!
Ummmmm.......yes, that would be the one. Sorry 'bout that superbad I spoke to soon. Don't know how I forgot that Randy as I know I have it marked down on my desk at home and I even put a tag on the contact ring with your name on it.
This is what happens when you have too many projects on the go simultaneously.
Let me know when you want it Randy. No rsuh on my part and you might want to wait until the hub gets finalized (and you source an airbag too).
by superbad » Wed 11.11.2009, 17:28
Do you have a part number for the contact ring?
superbad
by Elanlover » Wed 11.11.2009, 21:04
superbad wrote:Do you have a part number for the contact ring?
The contact ring is a GM part. On the contatc ring is a part number that reads 09 179 297. Just below that is another set of numbers reading 1 610 662. I have found these on eBay as a vauxhall part from time to time. If you search for contact ring you'll probably find a few.
This one isn't it but it loks like the plugs could be the same which is all you'll really want anyway. They look like this (although the airbag plug colour us diffrent on the two I have - blue/green and blue/yellow):
- 001.JPG (54.56 KiB) Viewed 6364 times
By the way, I think Lotos only needs the contatc ring so the steering wheel itself (less an airbag and contact ring) can be yours if you want.
