Lotus Aftersales closed as of 4th JAN
Re: Lotus Aftersales
Postby superbad » Fri 31.12.2010, 23:48
racerstev wrote:What's a door cheater panal??
Steve
Little triangular plastic panel behind the side mirror, held on with industrial velcro. That part number does not include the inner seal part, just the outer cover.
superbad
Postby Specky » Sat 01.01.2011, 09:51
May be THIS thread might help... :wink:
viewtopic.php?f=85&t=18389#p240922
Postby racerstev » Sat 01.01.2011, 16:36
Thanks guys, imagine that a part of my car that dosn't need replacment! LOL
racerstev
Postby lotusgirlmarie » Mon 03.01.2011, 08:26
Any chance I could get these bits let me know who to send off payment.
Elan M100 C100A0726F Longeron Assy RH (FED) 16 583.58 38.30
Elan M100 C100A0725F Longeron Assy LH (FED) 17 583.58 38.30
Elan M100 C100R0002F R/H DRIVESHAFT 40 356.69 93.61
Elan M100 A100E6570L HALL SENSOR(F/W) 96 N/A 12.77
Elan M100 A100E6393S OIL PIPE & STRAINER. 17 33.88 4.26
Elan M100 A100A0819F Engine Mounting RH Fed 4 66.86 4.26
Elan M100 A100E6472S Valve Assy-EGR TUR. 15 137.30 8.51
lotusgirlmarie
Goddess
Postby dunnlor » Mon 03.01.2011, 19:00
You have PM.
Tom (dunnlor)
dunnlor
Postby DaveB » Mon 03.01.2011, 19:45
HI... Any chance of...
Elan M100 E100V0094F CARPET-LUGGAGE FLOOR 4 26.78 5.11
M100 Elan G100V0002F Door trim RH (main trim panel) 8 218.69 42.55
... plus Left hand if any about...
M100 Elan A100V0785K Mask Facia RHD 32 16.07 4.26
Thanks for organising this... sad it has to end.
let me know how to pay... :cheers:
DaveB
Postby Specky » Tue 04.01.2011, 01:52
Lock Down.
Here's my plan, Pretty much the same as my first post.
1) Availability Check.
2) Inform you by PM of what is still available from your order.
3) Collect monies for items.
4) Pay and Collect items.
5) Work out Postage and packaging.
6) Collect Monies for P+P
7) Post your items to your chosen UK address.
8 ) Have a beer.
The list has been sent...........
Postby Specky » Sat 15.01.2011, 12:02
Just an update,
There is no update :(
I'm waiting on Lotus. :poke:
(I'll leave the thread locked at the moment until things start moving again)
Re: Lotus Aftersales closed as of 4th JAN
Postby Specky » Mon 31.01.2011, 19:53
Another update,
The Boys are still working on the list. :shock:
When I know something... you'll know.
Postby Specky » Tue 01.02.2011, 17:02
Got the list back....
I'll send out PM's in the next few days, but this should give you a heads up...everything else is still available from the list I submitted.
Be in touch...
Here's the obsolete list...
B100M6035F WASH BOT/PUMP & LEVEL SEN £12.77 QTY 1 obsolete
E100V0094F CARPET-LUGGAGE FLOOR £5.11 QTY 1 obsolete
B100V0066J FACIA MASK LHD £21.28 QTY 1 obsolete
A100M0068F DIGITAL CLOCK £8.51 QTY 1 obsolete
A100F6207S Synchronizer 1st & 2nd £21.28 QTY 1 obsolete
A100V0043F Jack Stowage Block £2.55 QTY 1 obsolete
A100F0020F Gaiter-Gear Shift £4.26 QTY 1 obsolete
A100F6206S Gear-1st Output £4.26 QTY 1 obsolete
A100F6205S Thrust Bearing-1st £4.26 QTY 1 obsolete
A100F6203S Output Shaft & Ring NA £4.26 QTY 1 obsolete
A100F6149S Input Shaft-Transaxle £ 4.26 QTY 1 obsolete
A100F6119S Block-Shift 1st/2nd £4.26 QTY 1 obsolete
D100L0014F Throttle Pedal LHD £3.40 QTY 1 obsolete
C100K0059F Lower Support Assy (Fed) £8.51 QTY 1 obsolete
C100A0726F Longeron Assy RH (FED) £38.38 QTY 1 obsolete
C100A0725F Longeron Assy LH (FED) £38.30 QTY 1 obsolete
C100K0059F Lower Support Assy (Fed) £8.51 QTY 1 Superbad obsolete
A100M0320F Cluster CAN-KPH/Unlead/SIR £55.32 QTY 1 obsolete
A100B0463F Lever-Bonnet Release RHD £0.85 QTY 1 Phil obsolete
A100V0785K Mask Facia RHD £4.26 QTY 1 obsolete
E100V0094F carpet luggage floor £5.11 QTY 1 obsolete
G100H0004F PAS rack&pinion RHD £127.65 QTY 1 obsolete
A100M0068F digital clock £8.51 QTY 1 obsolete
A100L6040F filler neck leaded unleaded £4.26 QTY 1 obsolete
B100M6035F washer bottle £12.77 QTY 1 obsolete
C100A0726F Longeron Assy RH (FED) £38.30 QTY 1LGM obsolete
A100A0819F Engine Mounting RH Fed £4.26 QTY 1 obsolete
A100E6472S Valve Assy-EGR TUR. £8.51 QTY 1 obsolete
E100V0094F CARPET-LUGGAGE FLOOR £5.11 QTY 1 Dave B obsolete
G100V0002F Door trim RH (main trim panel) £42.55 QTY 1 obsolete
A100A0819F Engine Mounting RH Fed £4.26 QTY 1 Matt obsolete
A100E6472S Valve Assy-EGR TUR £8.51 QTY 1 obsolete
A100L6040F FILLER NECK-LEADED & UNLEADED £4.26 QTY 1 obsolete
C100V0021F Insulation-Floor Pan LH £2.55 QTY 2 obsolete
A100E6472S Valve Assy-EGR TUR £8.51 QTY 1 a5gcd obsolete
C100M0008F Door Harness RH £8.51 QTY 1 obsolete
A100L6040F FILLER NECK £4.26 QTY 1 obsolete
H100A0252F Facia Cross Brace-RHD Turbo £17.02 QTY 1 obsolete
A100E6034F Temperature Sensor B2 £5.99 QTY 2 obsolete
Postby Monty » Tue 01.02.2011, 20:06
Dave,
Any chance of getting on the list :oops:
C100R0002F R/H DRIVESHAFT £93.61
C100R0001F L/H DRIVESHAFT £93.61
Postby racerstev » Wed 02.02.2011, 05:58
So this looks like my new list
My list and thank you for putting this all together for us!
1-A100B6167S Seal Kit-Falling Pillar LH 3 127.65
1-B100M6004F Switch for rear fog lamps 348 4.26
1-B100C0116F Wishbone-Upper/Fwd RH-Fed .85
1-B100C0117F Wishbone-Upper/Fwd LH-Fed .85
2-B100C0115F Wishbone-Upper Trail-Fed .85
1-B100M0149S Wiper Linkage LHD 29.79
1-A100U6024F Door Lock Cyls LH/RH & 1 Key 4.26
1-A100B1214F GRILLE-COOLER DUCT R/H USA 4.26
1-A100L6013F FUEL FILLER CAP .85
1-A100E6570L ****HONEYWELL HALL SENSOR(F/W) 12.77
1-A100B0238K Rear 1/4 Panel RH 17.02
I'd like to add because the less expensive one is no longer avalable
1- B100V0066J Facia mask LHD 42.55
I'd like to delete because the rest of the trans parts arn't avalable.
1-A100F6120S Shift Arm-3rd/4th 2 54.18 4.26
1-A100F6118S Selector Fork 1st/2nd 7 54.18 4.26
racerstev
Postby Specky » Wed 16.02.2011, 19:34
Just letting you know...
It's me holding things up,
I'm totally maxed at the moment, so a big sorry for not responding to messages etc
Hopefully normality will resume in a short while.
Postby lotusnut » Wed 16.02.2011, 20:37
No prob Specky, I think everyone appreciates what a huge task you have taken on and it will not happen overnight. Thanks again
lotusnut
Postby Don.Hasi » Thu 24.02.2011, 19:29
Hello Specky,
sorry in advance... I have read it several times but I have not just got it :bonk: Is it possible to do an order even now? If so, I would like to order the following:
1 A918E0130K Red cover for spark plug leads 17,02
1 A089S0282F R/H UNDERAXLE PIPE (PECO) 17,02
1 A089M8002P Headlamp Motor RH (F/W) 17,02
1 A089S0281F L/H UNDERAXLE PIPE (PECO) 17,02
1 B089B2548K Rad Duct Undertray-3099 On 21,28
2 B089D0791F Rear Top Link 13,62
1 B089S0279F PRIMARY SILENCER (PECO SLIP ON) 17,02
1 A089M8001P L/H HEADLAMP LIFT MOTOR 12,77
1 A089M8002P R/H HEADLAMP LIFT MOTOR 12,77
1 A089B2470K Front spoiler support rail (GFRP) 8,51
1 C912E2036K Cam Cover-Inlet (Red) 8,51
2 A089L6012F FUEL FILTER 10,22
2 A089D0312F REAR SPRING-RED/RED/RED 42,56
1 A089B2535F FRONT SKIRT 8,51
2 A912E2530F Engine Mount RH 8,52
1 A912E6917F Airbox Intake Temperature Sensor 4,26
1 K100A0319F Front Longeron LH 55,31
Again sorry, If I cause any additional work :oops:
Kind regards
Don
Don.Hasi
Postby MPx » Fri 25.02.2011, 00:15
I've heard elsewhere that GL may be about to do another sale so it could be that a new list will be produced and everyone will be able to order for themselves via their local dealer as per last time. Not sure on timing but March was mentioned. :D
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Postby GeoffSmith » Mon 14.03.2011, 21:23
UPDATE:
For those who got their list to Specky before his cutoff date - Everything on your list that Lotus had at that time should be reserved. We are working on the logistics at the minute: you will get a bill for the parts followed by a bill for delivery if they cannot be picked up or delivered. Please do not request the parts from Lotus or you may end with two of everything!
For those who got their list to Specky after his cutoff date - Sorry but they cannot be added to the original list, but there is another chance to get them off the new list.
Postby MPx » Mon 14.03.2011, 22:54
Thanks for helping with this Geoff. Good news for me if not some of the late entries. Awaiting further news with interest.
Happy to be tasked with somethiong if I can help. :cheers:
Mike - MPx
86 Turbo Esprit
MPx
Postby racerstev » Mon 04.04.2011, 04:57
Any updates on this? I hate to be pushy but this is holding up my project now.
racerstev
Postby Brit-Car-Nut » Tue 17.05.2011, 04:40
Greetings:
Everyone who placed an order should have received an email from me tonight or, for the few I didn't have an email address, a PM asking for an email address.
The orders have been tabulated and refined so you now get to see what is available and the cost to get it to LEC. Shipping to you will be figured on a member by member basis.
If you have placed an order but did NOT receive an email, check your PM inbox so you can send me your email address or let me know who you are and what you ordered and I will figure out why I don't have that information.
If your email address is now different from the one you listed on this forum, then send me the correct one (and fix your profile) and I will resend the invoice and instructions.
Thank you for your patience.
