Rear Hub/Disc conversion second run + Hi-spec brakes
Re: Rear Hub/Disc conversion second run
Postby CJ101KT » Tue 12.05.2009, 21:20
01. alexg + Brakes
02. whippit + Brakes (front and rear) +bearings (Front and Rear)
03. Jimmer
04. martin_bailey_1 + bearings fitted + discs to suit standard rear brakes (paid)
05. Max and Andy
06. Andy_J
07. Alan (ab2cv) + Brakes (front upgrade in the pipeline!) + bearings (paid)
08. BFG in the BRG - paid (hubs + Bearings + combined postage with the handbrake cables)
09. Ben (vi11ain) + Brakes
10. Exbury Paid (Wilwood 15" upgrade-ish)
11. CJ (Hubs + Bearings + Discs for standard caliper)
12. BigErch + Brakes (HiSpek 275 on the front)
13.Turners
14. texas2201 + bearings + discs for std caliper(paid)
15. ektrolleyboy + brakes
16. MPx + brakes (Hispec front in progress)
17. mnemonix + bearings + brakes (front & rear) Paid
18. Ekapol
19. ashm + bearings + discs for std caliper
20.kmckmc
21. ChrisP + brakes (hispec 298mm on the front)
22. saska = brakes
CJ101KT
Postby bobbrown » Tue 12.05.2009, 21:22
whippit wrote:bob i emailed you last tue, ive not had anything through, so thought you were to busy,
sorry , i dont want to miss out, so how do i get my detail to you, ???????
Do not know where that email went, cyber space some where
You have a pm
Pacific Blue N/A
Postby bobbrown » Tue 12.05.2009, 23:38
01. alexg + Brakes
03. Jimmer
05. Max and Andy
06. Andy_J
13.Turners
18. Ekapol
20.kmckmc
22. saska + brakes
23. MattDon
24. mvf906 + bearings + brakes (front and rear)
Pacific Blue N/A
Postby Ekapol » Thu 14.05.2009, 21:23
Removing my name from the list.
01. alexg + Brakes
03. Jimmer
05. Max and Andy
06. Andy_J
13.Turners
18. ashm + bearings + discs for std caliper
19.kmckmc
20. ChrisP + brakes (hispec 298mm on the front)
21. saska + brakes
22. MattDon
23. mvf906 + bearings + brakes (front and rear)
Ekapol
Re: Rear Hub/Disc conversion second run + Hi-spec brakes
Postby bobbrown » Sat 23.05.2009, 23:54
some pics of rear hubs with Hi-spec caliper upgrade.
Pacific Blue N/A
Postby mnemonix » Mon 25.05.2009, 12:12
Looks fantastic Bob. Do we have an ETA on this run now?
Chris.
mnemonix
Postby bobbrown » Mon 25.05.2009, 12:27
ETA is not clear at present and I am in the hands of Hi-Spec to some extent. Hubs should be done in about three weeks time, calipers are due to be done then but I would not hold your breath but I will start chasing Hi-spec this week as it seems if you don't they do not get done.
Pacific Blue N/A
Postby Nige » Mon 25.05.2009, 15:05
The photos above are of Bob's rear brakes on my car. The brakes were thoroughly bedded in at the Castle Combe track day on Saturday :roll: and the difference they made to the car was little short of astounding :shock: . I've had big brakes on the front for almost 6 years (Hi Spec Billet 4 and 300mm 2 piece discs) which had shifted the bias forward significantly. Whilst this was never a problem on the road on the track the rear wopuld be very light under braking, agian not a problem if you areexpecting it. On Saturday the car simply felt so much more stable under braking and my braking distances were significantly shorter as well. The conversion, hubs, discs and new calipers were an easy job to fit and I can highly recommend this if you already have a big brake set up on the front.
Back in Blighty
Nige
Postby CJ101KT » Sun 31.05.2009, 14:58
01. alexg + Brakes
03. Jimmer
05. Max and Andy
06. Andy_J
11. CJ (Hubs + Bearings + Discs for standard caliper) (paid)
13.Turners
19.kmckmc
21. saska + brakes
22. MattDon
CJ101KT
Postby whippit » Tue 02.06.2009, 20:43
01. alexg + Brakes
02. whippit + Brakes (front and rear) +bearings (paid)
03. Jimmer
05. Max and Andy
06. Andy_J
13.Turners
19.kmckmc
21. saska + brakes
22. MattDon
whippit
Postby mvf906 » Wed 03.06.2009, 11:46
01. alexg + Brakes
03. Jimmer
05. Max and Andy
06. Andy_J
13.Turners
19.kmckmc
21. saska + brakes
22. MattDon
23. mvf906 + bearings + brakes (front and rear) (paid)
me in my head, shifting & drifting, mechanical music, adrenaline surge
mvf906
Postby texas2201 » Tue 16.06.2009, 15:42
Hi Bob
Any news on the ETA of the rear hub and disks - Elan is going in for other work next Monday and just wondered if there was any chance of this turning up?
cheers
Martin :-D
Postby ashm » Wed 17.06.2009, 09:27
01. alexg + Brakes
03. Jimmer
05. Max and Andy
06. Andy_J
13.Turners
18. ashm + bearings (+ front hispecs, discs & pads + stainless hoses ) Paid
19.kmckmc
21. saska + brakes
22. MattDon
ashm
Postby mvf906 » Fri 19.06.2009, 10:38
[quote="ashm"]01. alexg + Brakes
03. Jimmer
05. Max and Andy
06. Andy_J
13.Turners
19.kmckmc
21. saska + brakes
22. MattDon
23. mvf906 + bearings + brakes (front and rear) + stainless hoses in red (paid)
mvf906
Postby bobbrown » Fri 19.06.2009, 11:13
Just a heads up on where we are.
Hi-Spec have said the rear calipers should be done in the next couple of weeks so that probably means 3 weeks!
Now there is likley to be a delay with the fronts as they have a shortage of the boot seals and as their stock control is non existant, they work on the we have run out principal.
They have them on order but they are saying they will not get them till mid July.
So those of you who have ordered just the rears are likley to see your kits before those that have ordered both front and rears.
The hubs should be done very soon like next week.
Pacific Blue N/A
Postby CJ101KT » Sun 21.06.2009, 15:35
bobbrown wrote:Just a heads up on where we are.
Thanks for the update, will be nice to have the hubs and new discs on the back.
CJ101KT
Postby martin_bailey_1 » Sat 04.07.2009, 05:17
bobbrown wrote:The hubs should be done very soon like next week.
Hi Bob,
Sorry to be a pain, but do you have any news on the hub/disc/bearing sets :?:
(as It's now nearing 'MOT time' :( )
Many thanks,
Martin.
martin_bailey_1
Postby stevieshag » Thu 16.07.2009, 19:31
Hi Bob,
Many thanks,
Martin.
black lotus elan se (kermit)
Mitsibushi outlander
suzuki gsx 750 W (Gonzo)
stevieshag
Postby bobbrown » Thu 16.07.2009, 23:39
I hope to have an update tomorrow.
A call into Hi-Spec to beat them up (got to make a call to Dartford any way) and a phone call to find out where the hubs have got to.
Pacific Blue N/A
Postby bobbrown » Fri 17.07.2009, 12:58
Update:
The hubs will be ready next week so hopefully I can start shipping those towards the end of the week
I do not have all the dosh in and you know who hasn't paid yet
Also I do not have all the names and addresses so could those of you who have not supplied details please do so by either email or PM and those of you who haven't paid.... well they aren't going any where till they are paid for.
I have to pay the £4000.00 + when I pick these up and I am covering the cost of the extras out of my own pocket.
I have spoken to Hi-Spec and they expect the fronts to be ready very soon like again next week and those who only have fronts ordered they will go out as soon as the kits are put together and boxed up.
The rears well I'm not sure but will be calling in this afternoon so will chase then.
01. alexg + Brakes
03. Jimmer
05. Max and Andy
06. Andy_J
13.Turners
19.kmckmc (paid)
21. saska + brakes
22. MattDon
24. Zoom
BTW: there are 6 pairs of hubs left if I have the numbers crunched correctly.
Pacific Blue N/A
