rip: just a point, the fronts can be adjusted with out taking the thing to bits, it is just a case of removing the rubber grommet in the middle and you should be able to get a small allen key into the holes that are around the top adjuster. I think the final solution is to fit an extension to the adjuster so it sits just outside the glass fibre part above the damper, or it would be quite simple to bend a piece of wire to fit the holes with a "T" on the top.
For those that may be interested one of the things that caused a moment of grief was the failure of the two anti roll bar mounts, the threaded section snapped off, a bit of a rethink was required other wise the job was not going to get done that day and would probably have meant a delay.
Solution: A quick trip to pick up some bits and they were soon sorted. What I did was get a couple of 12mm rose joints and some long cap screws, the cap screws with some spacers soon had the rose joint connected to the yoke mount, the hole needed redrilled in the anti roll bar from 10mm to 12mm which was no big deal and the rose joints were then connected coupled with a boot over the whole assembly to keep the muck out.
May need a little refinement but should come out a lot less than the £56.67 each (SL's prices), if they are still available these parts are.
It is possible to remove the damper/spring assembly with out taking the anti roll bar joint out but there is an issue of rust build up on the inside or at least there was with rip's that needs to be cleaned out to get the two halves of the yoke to fit properly.
The track day setup may need a little further thought as to what kind of spring rates are appropriate as these can now be increase to just about any setting you like with in reason but it may need a little thought in the damper lengths to maintain the current ride height or lower as the case may be.
Rips pics
- rear.jpg (59.89 KiB) Viewed 4975 times
- front.jpg (47.02 KiB) Viewed 4975 times
Not the best quaility as done on phone as I forgot to pick up the camera, early start to blame or at least thats my excuse and I'm sticking to it. Pete has some he took and will see it I can get those off him in the morning
