Front lower wishbone
Re: Front lower wishbone
Postby brian s » Tue 06.04.2010, 15:34
hi bob,
have transfered a further £150 to your account.
thanks
brian s
Postby BFG in the BRG » Wed 07.04.2010, 18:13
Hi Bob,
£150 transferred today - should be in you account immediately
Kind regards
BFG
Alas soon to be Elan-less
BFG in the BRG
Postby IanF » Wed 07.04.2010, 18:21
Hi, Have you still got space for another pair of wishbones?
I am a new boy with my Elan un-MOT'd and with a rotten OS front wishbone - it can only get better! Is delivery still hoped for end April/Early May?
Let me know how to get money to you if I am not too late to join the list.
Ian
IanF
Postby bobbrown » Thu 08.04.2010, 07:59
IanF wrote:Hi, Have you still got space for another pair of wishbones?
Ian
The date has probably slipped due to the material availability and getting it shipped from the USA probably looking at the end of May/ early June now
IanF if you still want in ping me a PM/email
Pacific Blue N/A
Postby Candles » Sun 11.04.2010, 20:59
£150 transferred to you.
Candles
Postby niall » Sun 11.04.2010, 22:04
£150 sent to your acount. It should appear in a couple of days.
:wink:
niall
Postby Paul Reid » Mon 21.06.2010, 14:05
Hi Bob,
Please will you update us on how this one is progressing.
Thanks,
Paul
Paul Reid
Postby bobbrown » Mon 21.06.2010, 15:12
Paul Reid wrote:Hi Bob,
Thanks,
Paul
All the metal is here and the process has started, it will take a little while to get it all cut and machined as there are something like 800 cuts just to reduce the tube and bar to the right lengths, plate is in the process of being laser cut and bent once these jobs are completed it is a cas of TIG welding them together a lot of work.
Pacific Blue N/A
Postby inkitin » Mon 21.06.2010, 18:20
Are you OK for money for these now? It did sound a really large outlay for you, to complete the run, out of your own pocket !
I'm happy to send you the balance, for my full amount, if it will help.
Roland
91 SE Calypso Red
inkitin
Postby bobbrown » Mon 21.06.2010, 19:00
All funds gratefully received
The sheet 1430 chrom moly steel was £250.00 a sheet times six sheets that's £1500 all the tubes etc (added up to about 90 meters) £2500.00 before I even started.
Then the cost to laser cut and bend the sheet, machine the parts, weld it together, galvanise the assembly, finish machine it etc, before you get to the bushes and the ball joints gets a bit frighnening but the end result should be well worth the effort as they will be half as strong again as the originals and made to last for years to come.
Make the most of it as I do not see me doing it again as it has take a lot of organising never mind the work to make them but there should be close to 50 sets when finished.
Note: the material above does include the tube for the rear upper links which are reasonably straight forward.
BTW: I've just calculated how many cuts I need to do just to get the material into the lengths required its 1650 just hope my bandsaw is up to the task and wonder how the blades will last at £33.00 each but at least it's not a DIY one as the blades are 3020mm long x 27mm.
Pacific Blue N/A
Postby inkitin » Mon 21.06.2010, 20:45
bobbrown wrote:All funds gratefully received.
Another £100 transferred. :-)
Thanks Bob
91 SE Calypso Red
inkitin
Postby niall » Mon 21.06.2010, 21:14
Thanks Bob. Further £90 sent.
niall
Postby Denny » Tue 22.06.2010, 08:02
Bob, a further £90 transferred to your bank today. Total paid £340.
Let me know if you need more when you have recalculated the total cost. Thanks.
Denny
Postby BFG in the BRG » Tue 22.06.2010, 21:54
Hi Bob,
a further £100 transferred just now - I believe this makes £350 total - but I'll check.
BFG in the BRG
Postby enndee » Tue 29.06.2010, 13:48
Hi Bob,
Red face time! :oops:
Just realised I haven't sent you my deposit for the wishbones yet!!!!! :(
£200 transferred to your account today! :D
Sorry!
enndee
Postby bobbrown » Mon 05.07.2010, 16:18
Parts are in the process of being cut out of the stock tube and bar but it takes a while as there are in excess of 800 cuts.............
Then it machining time again this will take a while as it is a lot of parts but progress is being made.
Pacific Blue N/A
Postby nicowalker1 » Wed 21.07.2010, 17:54
Bob, can you put me down for all parts for both sides?
nicowalker1
Postby Paul Reid » Thu 26.08.2010, 14:59
Bob,
Hopefully you are nearing the end on this epic job. Thanks again for your sterling work on all the parts you have developed.
I would like to make sure that you are not hurting for funds at this stage. If you have a final cost you want to declare, I would like to make sure I am fully paid up.
Cheers,
Paul.
Paul Reid
Postby brian s » Thu 14.10.2010, 15:45
hi bob, can you give us a progress update please,and do you have any idea of the final cost.thanks
brian s
Postby enndee » Fri 29.10.2010, 18:09
Everything seems to have gone very quiet on this project!!! :shock:
Bob, what is the current state of play please? :poke:
enndee
