Kuching Roll Hoops, Deck and Fairings
Postby paulwatkins » Fri 01.05.2009, 20:18
Seeing the photographs of Graham's (GUK) recent accident (SEE HERE) was a chilling reminder about how little protection the windscreen affords should the car turn over. Thankfully, Graham survived to drive another day but the images of the blood splattered on the seats had a lasting effect.
It started me off discussing with Simon Carrier, the possibility of producing a set of roll hoops. Simon is a long serving member of the LEC community and is extremely well respected. Simon is also the skilful chap that produced the well designed hard top. If anyone wants to check out Simon's crredentials just take a look at his website HERE.
Simon, has kindly agreed to do a another run of the roll hoops (and accessories) but needs a minimum of 10 takers to make it cost effective.
There are the structural roll hoops, rear deck and fairings. Simon can fit them if you want, or they an be fitted yourself (Monty fitted his own, Nige had his fitted by Simon).
The hoops can be fitted on their own or with the rear deck. The fairings can be fitted if you have the roll hoops and rear deck together.
Here are some pictures of what I am talking about. Some of you may of seen the items fitted on Nige's and Monty's cars.
Roll Hoops
Roll Hoops.JPG (21 KiB) Viewed 207137 times
Rear deck
Rear Deck.jpg (63.29 KiB) Viewed 207135 times
Fairings
paulwatkins
Re: Kuching Roll Hoops, Deck and Fairings
Postby paulwatkins » Fri 01.05.2009, 20:22
Here are some pictures of the fitted articles. I think you'll agree that they are very impressive!
First Nige's car
Nige's car
Nige rear close.jpg (61.11 KiB) Viewed 207142 times
Nige's car
Nige front.jpg (63.5 KiB) Viewed 207130 times
Nige's car
Nigel roll hoop 006.jpg (45.85 KiB) Viewed 207126 times
Nige's car
Nige close up.jpg (53.49 KiB) Viewed 207128 times
paulwatkins
Postby paulwatkins » Fri 01.05.2009, 20:24
And Monty's with just the roll hoops fitted (no rear deck or fairings)
Monty's car
Monty front.JPG (25.88 KiB) Viewed 207110 times
Monty's car
Monty rear.JPG (24.08 KiB) Viewed 207112 times
Monty's car
Monty side 3.JPG (45.43 KiB) Viewed 207108 times
Monty's car
Monty side 2.JPG (33.77 KiB) Viewed 207126 times
paulwatkins
Postby paulwatkins » Fri 01.05.2009, 20:26
And finally, Simon's own car and some of his initial design models
Design Image 3.jpg (81.59 KiB) Viewed 207118 times
Design Image 2.jpg (77.72 KiB) Viewed 207112 times
Design image 1.jpg (61.76 KiB) Viewed 207100 times
Simon's car
(191.07 KiB) Downloaded 5 times
Simon's car
Simon side 2.JPG (187.06 KiB) Viewed 207111 times
paulwatkins
Postby paulwatkins » Fri 01.05.2009, 20:27
The costs are as follows:
Roll hoops - £595
Rear Deck (unpainted) - £325
Fairings - £240
Fitting - £150
If you would like to join this run, and are serious about proceeding, please add your name to the following list
1. PaulWatkins - Roll hoops + Fitting
2.
3.
4.
5.
6.
7.
8.
9.
10.
paulwatkins
Postby Doug » Fri 01.05.2009, 22:43
wow, those are some seriously good prices, given the quality and design in them!! :shock:
Postby RichardK » Sat 02.05.2009, 06:54
Stunning work, yes I'm very interested.
Couple of questions -
WIth everything fitted is the soft top still 100% operational i.e. does it still fit under the rear deck and does it clear the fairings?
With everything fitted ( hoops, fairings) is it still possible to fit the SPC hardtop?
Also gotta to have a big think about how I would ship this kit to RSA.....
R
RichardK
Postby Nige » Sat 02.05.2009, 07:32
Richard, the answer to both of your questions is yes :D .
The soft top to fairing clearance is minimal (but it does clear if the soft top is fitted and adjusted properly).
My car has the hardtop on at the moment and it all fits over the hoops and fairings perfectly.
As far as shipping to RSA, I can't help you there. However, if you have a hard top already in RSA then these items are not as bulky to ship as a hardtop.
Back in Blighty
Nige
Postby markv » Sat 02.05.2009, 11:13
Just a couple of questions:-
- Where would fitting take place?
- Would the fairing look odd without the Rear Deck?
Roll hoops - £595
Fairings - £240
Fitting - £150
2. markv - Roll hoops + Fitting
3.
4.
5.
6.
7.
8.
9.
10.
Postby Nige » Sat 02.05.2009, 13:41
Mark, if you look at the photos of my car you'll see that the rear face of the fairing is designed to blend into the humps in rear deck. My personal view is that the fairings would look odd without the rear deck with the humps. I'll bring the S2 to the next H&C on Wed if you want to have a good look?
I imagine fitting would be by Simon at his works, which I assume is still at Sawtry (just off the A1 north of Peterborough).
Back in Blighty
Nige
Postby Monty » Sat 02.05.2009, 18:30
I`ll just add my 2 cents worth.
Simons Rool Hoops is a fantastic and well made product and i`m happy that there up to the job if the Pink Bomb ever decides to do a flip :shock: IIRC there are 11/12 fixing points.
I would recommend that you have Simon fit these as it`s no small job
A big :smt023 to SImon for doing another production run
Postby G UK » Sat 02.05.2009, 20:42
I'm not intending to make a career out of stopping Elans with my face and I most certainly do not want to experience being trapped dangling upside down off of my seatbelt watching the floor and remains of the roof slowly turn red again. Still better safe than sorry!!
As you can probably tell I 100% recommend this product.
3. G UK - The Works + Fitting
4.
5.
6.
7.
8.
9.
10.
https://gridcoin.ddns.net
G UK
Postby ailwyn » Sat 02.05.2009, 22:18
Currently unemployed so subject to the outlook being more positive by the time this buy happens... hence the possible status.
4.
5.
6.
7.
8.
9.
10.
Possibly depending on various factors
1. Ailwyn - the works + fitting + painting (if available)
Postby superbad » Sun 03.05.2009, 05:09
4.
5.
6.
7.
8.
9.
10.
1. Ailwyn - the works + fitting + painting (if available)[/quote]
2. superbad (the big factor would be shipping to the US, and what's involved in self-fitting)
superbad
Postby BFG in the BRG » Wed 06.05.2009, 17:59
What is the time line on this - I am tempted but am wrestling with the finances - plus do you happen to know if the Classic Additions Wind Blocker compatible? - looking at it, it might just need a modified bracket made up.
4.
5.
6.
7.
8.
9.
10.
3. BFG - Rollhoops + Fitting
Alas soon to be Elan-less
BFG in the BRG
Postby RichardK » Wed 06.05.2009, 18:06
With the condition that someone has to make a video of the fitting so mechanically hopeless here can stand a chance of fitting it all properly.....on the other side of the world.
4. Richard K - The Works + Instruction "Video"
5.
6.
7.
8.
9.
10.
RichardK
Postby abmunro » Wed 06.05.2009, 21:02
There is a facility in the Loop fairing to have a perspex wind deflector made and fitted.
There are 4 tapped screw holes
Tony
BFG in the BRG wrote:What is the time line on this - I am tempted but am wrestling with the finances - plus do you happen to know if the Classic Additions Wind Blocker compatible? - looking at it, it might just need a modified bracket made up.
4.
5.
6.
7.
8.
9.
10.
3. BFG - Rollhoops + Fitting[/quote]
abmunro
Postby Andy_J » Wed 06.05.2009, 22:30
5.
6.
7.
8.
9.
10.
4. Andy_J - Rollhoops + Fitting
90H BRG SE 48,000 Miles
Andy_J
Postby Elanlover » Thu 07.05.2009, 01:19
5.
6.
7.
8.
9.
10.
5. Elanlover - rear deck only but shipping costs could be a factor
Postby lotos » Tue 12.05.2009, 18:03
Any idea what shipping to US would run?
lotos
