Rear Hub conversion 3rd run
Postby bobbrown » Mon 21.06.2010, 15:23
Ok some people have asked regarding another run on these so here's another list.
Just hubs and bearings on this list please and PM me if you want brakes as well.
I will need a minimum of 20 people to make it economic and indicate if you want bearings as well. The price will be the same as last time at £130.48 for the hubs and £24.00 for the bearings, thats axle sets so a pair.
Pacific Blue N/A
Re: Rear Hub conversion 3rd run
Postby Rice crispy » Mon 21.06.2010, 17:36
Well why not :D
1. lansledj hubs/bearings please
Many Thanks Bob, will buy you a drink if you are out on 30th (being a Driver for Spud) for Curry night
Rice crispy
Postby Candles » Mon 21.06.2010, 21:34
2. Candles: Rear hubs and bearings. Will want the rear discs and calipers so PM inbound....
Thanks for getting this going again Bob.
Candles
Postby tonny006 » Wed 23.06.2010, 22:17
3.tonny006 hubs only please
well done Bob,have wanted these for a long time
tonny006
Postby Paul Reid » Thu 24.06.2010, 09:00
3. tonny006 hubs only please
4. Paul Reid: Hubs and bearings. Brakes all round too! PM sent.
Thanks for running this again Bob.
Paul Reid
Postby Nick Shepherd » Thu 24.06.2010, 13:02
Hi
New to all this which discs would I have to buy?
Nick Shepherd
Postby nicowalker1 » Thu 24.06.2010, 15:43
5. Nicowalker1 hubs and bearings (provisional)
would i need any special tools to do this job?
nicowalker1
Postby ashm » Thu 24.06.2010, 17:22
Nick Shepherd wrote:Hi
From the previous group buy thread:
dapinky wrote:I know that this is a 'list' thread, not specifically an 'information' one, but it may help people on the list, or from the first buy.....
The disks required to fit the 'standard' rear brake calipers (and these hubs) is an Apec DSK117.
rear (DSK117) are listed for a Vauxhall Astra 1.4 ('91-'98) at £6.51 each.
They arrived within 48 hours, and the company (as well as being the cheapest 'All In' price I could find) were easy & helpful to deal with.
Adam
ashm
Postby jimbob » Thu 24.06.2010, 23:31
Sorry to be akward but has anyone got a photo of these hubs for a look see ?
And also are the bearings the same dimensions as the originals
Regards Jamie
08 VW Caddy TDi
jimbob
Postby bobbrown » Fri 25.06.2010, 00:10
There are pics in the previous run topics but heres another
Shown mounted on a rear hub and the every thing is the same as the original, like bearings etc just less the disc and the material is now steel instead of cast iron so stronger than the original, add a solid Vauxhall/Opel/GM disc and you have something that is the same as the original and can be used with the standard rear calipers and the discs then become less of a problem as they are cheap as chips at £15 to £20 the pair and easy to get hold.
Pacific Blue N/A
Postby tigerdog » Fri 25.06.2010, 19:24
Bob, could you please approximate US shipping costs for just the hubs? I assume I could source the bearings and discs here.
Postby bobbrown » Fri 25.06.2010, 20:30
Last time I shipped these to the USA they were shipped as a group and then forwarded out to individuals, I think a pair shipped would be £35.00 to £40.00 more equals less
Bearings and discs are available in the USA
Information
For those of you that are purchasing these, the discs required to run with the standard rear caliper are as follows:
236 diameter 12.5mm thick, height 41mm 4 stud 100mm PCD
North America
PONTIAC LEMANS (1988 - 1989)
PONTIAC LEMANS AEROCOUPE 1988
PONTIAC LEMANS AEROCOUPE YL (1988 - 1989)
PONTIAC LEMANS SE 1988
PONTIAC OPTIMA (1988 - 1989)
also I believe they were fitted to an Isuzu Optima in Canada 1988 1989
RockAuto Raybestos part number 5966R $19.76 each so you will need 2
Bearings are also available
BCA/NATIONAL Part # A15
National 4175 BCA 4175 Automotive Oil Seal
http://www.woodys-auto-supply.com/
brg: BCA-A1
brg: BCA-A15
seal: NAT-4175
Pacific Blue N/A
Postby ktskisail » Tue 06.07.2010, 13:26
Somehow I have lost my old username so now have a new one...
Anyway I am also looking to replace my rear hubs/discs. If this run is still available I would like to join the list... I will need hubs and bearings, also discs/pads if they can also be bundled?).
ktskisail
Postby bobbrown » Tue 06.07.2010, 14:31
I can probably sort out the details with regards to bearings, discs, pads etc when we have enough people on the list to make it economic to place the order to get them machined.
6. ktskisail hubs and bearings
Pacific Blue N/A
Postby AndyT » Tue 06.07.2010, 21:59
7. Andyt Hubs and Bearings please
AndyT
Postby mellowyellow » Wed 07.07.2010, 07:25
mellowyellow Hubs and Bearings please
mellowyellow
Postby bobbrown » Wed 07.07.2010, 07:53
8. mellowyellow Hubs and Bearings please
Pacific Blue N/A
Postby owentec » Sun 11.07.2010, 08:58
9. owentec Hubs and Bearings please
owentec
Postby kenich » Sun 11.07.2010, 09:56
10. Kenich - Hubs and Bearings please (depending on when funds are needed by but should be good for the £££)
kenich
Postby Brit-Car-Nut » Wed 14.07.2010, 16:50
11. Brit-Car-Nut - Hubs only please - going to US.
