Stainless steel gear shift cables
Postby bobbrown » Sun 22.05.2011, 17:31
For details and comments see link
This is a list for a pair of gear shift cables in stainless steel fitted with rod ends to allow for any misalignment, it also means that it does not stop the gear lever from self centering.
I have now finalised the price, IF we can get to 25 then they will be £210.00, or if not then they are £230.00 both plus £8.00 delivery.
If you have a S2 Elan then you will not need the gearbox bracket so deduct £16.00.
For those in the USA they may want to consider sourcing the cables locally as they are a standard cable all be it a specific length.
1. Tannerman pre production cables being sent 22nd May
2.
3.
4.
Pacific Blue N/A
Re: Stainless steel gear shift cables
Postby Steve A » Sun 22.05.2011, 20:58
Thought we did this already :smt017
2. Steve A
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
Postby DavidEJM » Sun 22.05.2011, 21:08
2. Steve A
3. DavidEJM
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
Oooooh shiney!
DavidEJM
Postby cliff » Sun 22.05.2011, 21:39
2. Steve A
3. DavidEJM
4. Cliff
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby superbad » Mon 23.05.2011, 03:26
bobbrown wrote:For those in the USA they may want to consider sourcing the cables locally as they are a standard cable all be it a specific length.
I can look into this if you have the cable details available. I located a few potential sources a while back.
superbad
Postby Brit-Car-Nut » Mon 23.05.2011, 05:41
I am also willing to do it on the East Coast. I have several cable builders available but they didn't have the propper ends.
Postby Denny » Mon 23.05.2011, 07:54
2. Steve A
3. DavidEJM
4. Cliff
5. Denny (SE)
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
Denny
Postby Paul69 » Mon 23.05.2011, 08:16
how do you attach its to early for this!
Paul69
Postby bobbrown » Mon 23.05.2011, 09:48
A result :banana:, a couple of phone calls later and I've now managed to source the cables at a better price all be it the discount for volume gets thrown out of the window but it means we do not have to reach 25, they will be £210.00 a set how ever many cables I order.
They have enough parts in stock to make up 5 pairs of cables and can order in some more parts from the USA.
So first come first served and I'll do a run of 5 sets with the others to follow allowing them three weeks or so to get the parts in from the USA for the cables.
For those in the USA the cables are Felsted all stainless steel part numbers M4222 /1210 and 1235 the last numbers are the overall length it mm and the ends are M6 not the standard 1/4". To clarify the cross gate is 1235mm and the main cable is 1210mm overall length with 2" of travel.
For just the parts I make up less cables and rod ends (available from Mid West Controls USA DSTF-6 2 off and DSTF-8 2 off) cost will be £65.00 plus delivery
Geoff raised the question with regards to cable lengths, they may appear short but you have to add in the rod ends and adapters which takes them to the original lengths give or take a little bit as there is 20mm of adjustment on the cable lengths c/o the rod ends and adapters. That adjustment is in addition to the adjustment on the cable bracket which is another 25mm
2. Steve A
3. DavidEJM
4. Cliff
5. Denny (SE)
6. Paul69
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
Pacific Blue N/A
Postby JonT » Mon 23.05.2011, 14:46
2. Steve A
3. DavidEJM
4. Cliff
5. Denny (SE)
6. Paul69
7. JonT
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
JonT
Postby Brit-Car-Nut » Mon 23.05.2011, 16:19
For those in the USA the cables are Felsted all stainless steel part numbers M4222 /1210 and 1235 the last numbers are the overall length it mm and the ends are M6 not the standard 1/4". To clarify the cross gate is 1235mm and the main cable is 1235mm overall length with 2" of travel.
Bob:
Acording to Felsted, there is a prefix missing It is 3 digits that identifies the type of ends on the cable.
First digit:
Cable Types
0 Solid Core (3 Series)
1 HP Cable Standard (Temperature –65 to +225°F/–54 to +107°C)
2 All Stainless Steel Fittings
3 HEFT 2 (High Temperature –65 to + 300°F/–54 to + 149°C)
4 HEFT 2 (High Temperature –65 to + 300°F/–54 to + 149°C)
With all Stainless Steel Fittings
Last 2 digits:
Control Head Options
00 None — Cable Without Head
73 Positive Lock Quick-Disconnect Head: 3” Travel
75 Positive Lock Quick-Disconnect Head: 5” Travel
90 Vernier Head: Small, Black, Quick-Disconnect
92 Vernier Head: Large, Black, Quick-Disconnect
94 Vernier Head: Large, Black with Red Button, Quick-Disconnect
Please pass that info on so I can see who has the better price for the cables.
Cable-Tec is also a big supplier and more common in my area. They claim to be able to provide the same quality cable for less cost.
I will also give them a try once i have the specific details for the cables you are using.
Thank you.
Postby Brit-Car-Nut » Mon 23.05.2011, 16:45
Bob:
Another question came up as to the type of bulkhead: The Stainless 5/8" bulkhead is very expensive compared to the normal steel.
My supplier says the never use stainless bulkheads, just stainless cables, sleeves and ends.
Can you confirm that the bulkheads are 5/8" and they are standard steel? Or are they aluminum??
Thank you.
Postby bobbrown » Mon 23.05.2011, 18:09
All I can say is that the ones I use are stainless steel through out including stainless steel bulkhead fitting, I did not see any good reason to go for plated steel fittings as there was not enough differance in cost to justify a part that will rust in time.
These cables are 4 series with both ends the same but the thread on the end M6 not 1/4-28 UNF
Your supplier can not be in the marine industry as they would always specify stainless steel through out as steel and salt water do not get on very well together.
If you want to do the job with steel fittings thats up to you as long as the threads remain the same for the bulkhead fitting , the ends are M6, with the dimension B = 6.19" (157.2mm) and overall length remaining the same other wise I can not say if they will fit or not.
Pacific Blue N/A
Postby Brit-Car-Nut » Mon 23.05.2011, 18:31
Not looking to modify, looking to duplicate what you have worked out.
Cable prices with all stainless at 50% discount are still much higher than what you are quoting so I am doing something wrong.
Thank you for the drawing.
I will keep looking. Felsted is actually a dead company. I spoke to the original group and they said it was dissolved 3 years ago.
Maybe that is why I am having trouble getting a decent quote.
Postby superbad » Mon 23.05.2011, 21:01
Bob-
I'm just getting some quotes on these- both ends of the cable are M6 right? Those DSTF-8 rod ends are M8.
superbad
Postby bobbrown » Mon 23.05.2011, 21:04
Correct both ends M6 then an adapter to get to the M8 rod ends
Pacific Blue N/A
Postby superbad » Mon 23.05.2011, 21:18
Got it. Is that adapter part of the kit you are making?
superbad
Postby bobbrown » Mon 23.05.2011, 21:24
yes
For peoples information the cable part number 4222 breaks down like this 4 is the series of cable, next 2 is the length of travel, next 2 is for a bulkhead fitting and the last 2 is a bulkhead fitting so reads 4series, 2" travel with bulkhead fittings either end.
2. Steve A
3. DavidEJM
4. Cliff
5. Denny (SE)
6. Paul69
7. JonT
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
Pacific Blue N/A
Postby bobbrown » Tue 24.05.2011, 13:00
Brit-Car-Nut wrote:Felsted is actually a dead company.
Felsted is now part of the Orscheln group see Orscheln which is an American company
Pacific Blue N/A
Postby Brit-Car-Nut » Tue 24.05.2011, 15:36
That is who I am dealing with.
I have a source that will make cables for me. They will provide better pricing if I buy 5 to 10 at a time.
I am working on the heim joints. I think I can do better than Midwest but have to wait for my rep to get best prices.
Can you figure out how much it will cost for your adapter/bushing kit to be shipped to the US?
Bob: Why haven't you responded to the Aftersales communications you received?
