Page 1 of 1
LEC tax disc holder (cat on skates)
PostPosted: Fri 22.06.2012, 07:13
by theelanman
ok......mine fell apart the other week when putting in my new tax disc......
so I thought how about getting some LEC ones done......
you know the score.....see through front, white back.......and I thought...cat on skates logo on the back...
would there be any interest.......
depending on numbers they would be between £4 and £5......
(if we manage to get to 200 it'd come down to £3.....but Im not sure we'd get that many)
feel free to start a list
Re: LEC tax disc holder (cat on skates)
PostPosted: Fri 22.06.2012, 07:20
by theelanman
Vinyl welded circular disc with self cling backing. Outer clear self cling: 101mm dia.
Inner vinyl disc: 82mm dia. Die cut with three point opening on back.
btw they call the front the back.......ie the self cling that sticks to the window I would call the front.....as its forward facing....but they call it the back....... :roll:
PostPosted: Fri 22.06.2012, 09:15
by Breed
Hi
In case you cannot get enough takers to do this
If you have any of the large cat on skates round stickers they stick on the Halfrauds Magnetax Magnetic Tax Disc Holder
Cat. code: 382994-0 with very little trimming. only £2.99 and should last as long as the car. Looks very pofessional and works well. It has a magnetic ring
that sticks to the window and a metalised back. Very easy to change tax disc. In the picture it looks as though it has raised edges but it is actually flat.
Bill
PostPosted: Fri 22.06.2012, 09:36
by theelanman
that an idea.......but a job lot of stickers and holders would be needed...... and would you send out the DIY pack or would they be a finished item....... :-D
probably still about £4......incl sticker
just a thought
PostPosted: Fri 22.06.2012, 10:13
by Rice crispy
1. Lansledj
2.
PostPosted: Sat 23.06.2012, 15:13
by Denny
1. Lansledj
2. Denny
3. Denny
4.
PostPosted: Sat 23.06.2012, 15:33
by stuartm
1. Lansledj
2. Denny
3. Denny
4. stuartm
PostPosted: Mon 06.01.2020, 16:37
by GeoffSmith
I guess the DVLA killed this one off.
PostPosted: Mon 06.01.2020, 19:10
by KenCarson
I still have the original Bell & Colville holder from 1992 :)
