Wheel Arch Liner Kit (Front) £12.00 - Still a few kits left
Postby BFG in the BRG » Fri 10.08.2012, 12:12
I have to say, I never realised how useful it is to be able to remove the front wheel arch liner, so many areas to access (feel free to add what other things there are under there) but so far for me.......headlight pods, turbo cooling radiators, Oxygen sensor wiring loom, access for replacing timing belt (I think - it was 5 years ago that I did this...so due again :( ).
Trouble is....a combination of 20 year old car, siezed bolts and low headed bolts which would have been difficult to remove when new - let alone now, makes getting the liner off is a project in itself.
So the only way I've found to get the wheel arch off is to grind/cut off the fixings where they are siezed using a Dremmel Multi-tool with a flexible shaft, spraying the area to keep things cool - you would be amazed how useful a Dremmel is.
So.......I've sourced all the replacement fittings in stainless steel/brass where possible.
Sufficient for both front wheel arches the kit will consist of:
Tube Epoxy Resin (for fitting rubber rawl plugs)
4 x rubber rawl plugs (Neoprene rubber over M6 brass threaded section)
4 x M6 Lug Nuts(zinc plated steel)
8 x M6 Dome nuts (Stainless Steel)
8 x Penny Washers (Stainless Steel)
6 x Self Tapping Screws (Stainlesss Steel)
6 x Penny Washers (Stainless Steel)
6 x Plastic Plugs
COST £15.00 including POSTAGE TO UK and a donation to LEC - might be a bit less if I get sufficient numbers
Overseas will be a bit extra - but I won't rip you off
So - if you are interested put your name on the list below.
I'll close the list on 31st August, place the order and ask for the cash preferably by electronic transfer/cheque or as a last resort - paypal.
List for the wheel arch liner fittings kit (£15.00)
1)
Alas soon to be Elan-less
BFG in the BRG
Re: Wheel Arch Liner Fittings Kit (Front).... £15 at the mom
Postby Rice crispy » Fri 10.08.2012, 12:22
6 x Plastic Plugs
Many thanks for doing this :D
1. Lansledj
2.
Rice crispy
Postby steve matthews » Fri 10.08.2012, 12:47
1. Lansledj
2. Steve M
steve matthews
Postby epipete » Fri 10.08.2012, 13:09
steve matthews wrote:
1. Lansledj
2. Steve M
3. Epipete
Postby ashm » Fri 10.08.2012, 13:57
1. Lansledj
2. Steve M
3. Epipete
4. ashm
ashm
Postby Gary1958 » Fri 10.08.2012, 14:17
ashm wrote:List for the wheel arch liner fittings kit (£15.00)
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
Gary1958
Postby Brit-Car-Nut » Fri 10.08.2012, 14:59
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8.
9.
10.
11.
12.
13.
14.
15.
Postby woody » Fri 10.08.2012, 17:01
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody x 2
9.
10.
11.
12.
13.
14.
15.
woody
Postby BFG in the BRG » Fri 10.08.2012, 18:36
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.
11.
12.
13.
14.
15.
BFG in the BRG
Postby nicowalker1 » Fri 10.08.2012, 18:51
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
15.
nicowalker1
Postby GeoffSmith » Fri 10.08.2012, 19:29
Do the Geordie Blingmeisters detect a new kid on the block? :lol:
Seriously, having had to take the wheel arch liners off a couple of time since fitting DeeAitch's wheel arch kits, this is well worth doing.
Postby Andy_J » Fri 10.08.2012, 19:35
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
15.Andy_J
90H BRG SE 48,000 Miles
Andy_J
Postby alan e » Fri 10.08.2012, 19:43
Andy_J wrote:1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
15.Andy_J
16 alan e
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby BFG in the BRG » Fri 10.08.2012, 20:25
What, you mean this wasn't an original idea :oops:
Ah well
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
12.Andy_J
12+1. Alan e
14.
BFG in the BRG
Postby cliff » Fri 10.08.2012, 20:32
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
12.Andy_J
12+1. Alan e
14. Cliff
15.
16.
17.
18.
19.
20.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby DaveB » Sat 11.08.2012, 09:49
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
12.Andy_J
12+1. Alan e
14. Cliff
15. DaveB
16.
17.
18.
19.
20.
DaveB
Postby DavidEJM » Sat 11.08.2012, 11:43
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
12.Andy_J
12+1. Alan e
14. Cliff
15. DaveB
16. DavidEJM
17.
18.
19.
20.
Oooooh shiney!
DavidEJM
Postby HJ2 » Sat 11.08.2012, 12:21
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
12.Andy_J
12+1. Alan e
14. Cliff
15. DaveB
16. DavidEJM
17. HJ2
18.
19.
20.
Postby G UK » Sat 11.08.2012, 12:27
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
12.Andy_J
12+1. Alan e
14. Cliff
15. DaveB
16. DavidEJM
17. HJ2
18. G UK
19. G UK
20.
https://gridcoin.ddns.net
G UK
Postby madbilly » Wed 15.08.2012, 21:24
1. Lansledj
2. Steve M
3. Epipete
4. ashm
5.Gary1958
6. Brit-Car-Nut
7. Brit-Car-Nut
8. Woody
9. Woody
10.nicowalker1
11.nicowalker1
12.Andy_J
12+1. Alan e
14. Cliff
15. DaveB
16. DavidEJM
17. HJ2
18. G UK
19. G UK
20. madbilly
madbilly
