Headlight stainless fasteners & springs GB#2 @ £25 (ROW+£2)
Postby GeoffSmith » Tue 23.10.2012, 16:27
A few people have asked about the headlight stainless springs and fasteners after the first Group Buy sold out. If enough people sign up to it, I'll organise another run (the springs are made to order) - depending on the numbers, the prices are likely to be as follows:
Code: Select all
Sets      Price per set
>  1       £55
>  2       £39
>  3       £36
>  4       £31
>  7       £28
>  9       £23
> 13       £21
> 17       £18
> 60       £15
UK prices incl P&P
ROW prices add GBP2
Re: Headlight fasteners and springs - stainless group buy #2
Postby Ralph » Wed 31.10.2012, 12:25
Hi Geoff, I'll definitely taketwo sets. :)
Elan S2 No. 221 in Azure Blue (with AirCon - WooHoo)
Ralph
Postby GeoffSmith » Wed 31.10.2012, 22:13
Code: Select all
Sets      Price per set
>  1       £55
>  2       £39
>  3       £36
>  4       £31
>  7       £28
>  9       £23
> 13       £21
> 17       £18
> 60       £15
UK prices incl P&P
ROW prices add GBP2
1. Ralph
2. Ralph
3.
Postby KevB » Mon 30.12.2013, 10:32
CODE: SELECT ALL
Sets Price per set
> 1 £55
> 2 £39
> 3 £36
> 4 £31
> 7 £28
> 9 £23
> 13 £21
> 17 £18
> 60 £15
UK prices incl P&P
ROW prices add GBP2
1. Ralph
2. Ralph
3. KevB
KevB
Postby rip » Mon 30.12.2013, 11:50
CODE: SELECT ALL
Sets Price per set
> 1 £55
> 2 £39
> 3 £36
> 4 £31
> 7 £28
> 9 £23
> 13 £21
> 17 £18
> 60 £15
UK prices incl P&P
ROW prices add GBP2
1. Ralph
2. Ralph
3. KevB
4. rip
Postby Rusty Wishbone » Thu 02.01.2014, 23:36
Sets Price per set
> 1 £55
> 2 £39
> 3 £36
> 4 £31
> 7 £28
> 9 £23
> 13 £21
> 17 £18
> 60 £15
UK prices incl P&P
ROW prices add GBP2
1. Ralph
2. Ralph
3. KevB
4. rip
5. Rusty Wishbone
Rusty Wishbone
Postby Fredjohn » Thu 02.01.2014, 23:47
Rusty Wishbone wrote:A few people have asked about the headlight stainless springs and fasteners after the first Group Buy sold out. If enough people sign up to it, I'll organise another run (the springs are made to order) - depending on the numbers, the prices are likely to be as follows:
Sets Price per set
> 1 £55
> 2 £39
> 3 £36
> 4 £31
> 7 £28
> 9 £23
> 13 £21
> 17 £18
> 60 £15
UK prices incl P&P
ROW prices add GBP2
1. Ralph
2. Ralph
3. KevB
4. rip
5. Rusty Wishbone
Geoff
You originally made this post to create a 2nd group buy in Oct 2012, and people have been adding names again from Dec '13. For the sake of clarity are the prices and thread still actually valid?
Ta.
Postby GeoffSmith » Fri 03.01.2014, 19:25
I haven't checked up on prices recently but the main cost driver is the springs which are made to order. Hopefully things won't have changed too much, so I'll probably use the kitty to order a load of springs then get the fasteners when required as it looks like one of those things that will tick over at a low level when people start working on their headlights and doing some research on LEC. I'll aim to make the price no more than £25 for a full set.
One other thing I looked at was getting the mounting plates cut in stainless. I have a pattern (minus the return flange dimensions) and I was hoping to get to talk to a local fabricator when picking up some front castor shims but I haven't been given the nod by Pinky yet. :poke:
Postby dapinky » Fri 03.01.2014, 20:10
GeoffSmith wrote:...... I was hoping to get to talk to a local fabricator when picking up some front castor shims but I haven't been given the nod by Pinky yet. :poke:
They shut down for a fortnight over the holiday period - so I'll chase them up next week.
Postby Elanlover » Mon 27.01.2014, 15:10
1. Ralph
2. Ralph
3. KevB
4. rip
5. Rusty Wishbone
6. Elanlover
Postby Jeemy » Mon 27.01.2014, 16:28
I'm in for mounting plates.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby Brit-Car-Nut » Mon 27.01.2014, 19:57
Jeemy wrote:I'm in for mounting plates.
I believe this is only for the screws and springs.
I believe SJS was doing a set in galvanized?
Postby Jeemy » Wed 29.01.2014, 17:08
Going to just refurbish mine but as Geoff mentioned the possibility of stainless, I'd contribute to that. I've got the V1 of this kit - I am deep into the lights/electrics at the moment and should have a big update to my project soon when I have a solid set of work to report on.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby grahamec » Sat 15.03.2014, 20:27
Add me to the group buy list please.
Grahame
grahamec
Postby novacaine » Sat 15.03.2014, 20:55
Just to check, what part are the fasteners?
novacaine
Postby Brit-Car-Nut » Sat 15.03.2014, 21:24
The screws: 12 off of item #4, item #12 (button head plus washer) & item #13 plus the four P clip (harness) retaining screws.
and springs: 12 off of #14
These are for the later POD type headlamps, not the early Opera design.
Postby novacaine » Tue 18.03.2014, 19:55
In that case my fasteners are still pretty good, although I could do with a set of part 3 from that diagram at some point
novacaine
Postby WienLot » Tue 18.03.2014, 21:12
Hello all,
What part is 'mounting plate' ? Thx
WienLot
Elan SE turbocharged 1991
1) “ If it works, don't fix it ”
2) Never give up...!
WienLot
Postby HJ2 » Wed 19.03.2014, 11:07
1. Ralph
2. Ralph
3. KevB
4. rip
5. Rusty Wishbone
6. Elanlover
7. HJ2
8. HJ2
Postby Brit-Car-Nut » Wed 19.03.2014, 16:30
WienLot wrote:Hello all,
WienLot
Items 10 and 11. Mostly obsolete from Lotus. SJs had some done in galvanized. Geoff looked into Stainless, but nothing went further.
If there is a demand, I have a full set of new plates for patterns, I can have them made in the US but like everything else, the shipping is not friendly. I am sure stainless is available as is plated steel like the originals.
