See here http://forum.lotuselancentral.com/viewtopic.php?f=64&t=9281&hilit=puck&start=20 and Monty's post of 12/08/2009
Instead of using a IIRC 19mm (
so here's the deal
1) buy one yourself off Fleabay and do the mod - it's really easy...but one of those insignificant jobs that you will keep meaning to do....and then you'll lost the puck...etc
2) I'll do the work, get covered in molted black rubber and post one to you
Cost..........................
Around £6 including postage to UK and £1 donation to LEC coffers for each one, overseas will be whatever the additional postage is - price will drop with sufficient numbers.
Don't expect it to be lazer cut and machine drilled - it will be hand made and rustic - but it will work, if nothing else it'll be something you can keep in the boot and hand to a mechanic before they attempt to jack the car up.
So here goes.... as many as you like
1.
2.
3.
4.
5.
Can't you just tell the winter nights are drawing in...the BRG is in the garage hibernating.......and I'm getting bored
