Replacement Outer Door Strips from PNM
Moderators: theelanman, Sy V, Elanlover, muley, Enright, GeoffSmith, algirdas, nitroman, clemo, dapinky, Dave Eds, Specky, Nige, DaveT
Re: Replacement Outer Door Strips from PNM
Postby KevB » Tue 25.02.2014, 12:53
Yes please, one pair, mine are shot!
can you hold till Friday? cash flow problem :roll:
Kevin
KevB
Postby dapinky » Tue 25.02.2014, 13:24
Kev,
I've held them for 6 months, so a bit longer is no problem at all!
Logistically, I am off to Vietnam on Friday, and not back until 19th March - if you are happy to wait, we can sort it all out when i get back, but if you have seen a rare glimpse of sunshine and want to get on with the job, then just PM me your address and I'll get a set out to you before I go - we can sort the payment later.
Postby abmunro » Thu 07.12.2017, 23:10
[quote="Brit-Car-Nut"]PNM has offered LEC a one time discount for the weather strips if we can order more than 25 sets. This only came about after so many were asking for replacements.
A set or a pair is both sides or enough to do the entire car.
Go to the bottom of this page: http://www.pnmengineering.com/lotus-bodywork-chassis.html
Wienlot made the introduction for LEC and PNM has been very generous in making their offer.
Everyone needs to take a look at their strips and decide if they need/want a new set.
If you want to see how to get to the strips to replace them, see http://wikilec.9600.org/index.php/Door_Trim.
Also http://www.lotuselanm100usa.info/lec/Door%20Card%20Removal-1.pdf
and http://www.lotuselanm100usa.info/lec/Door%20Card%20Removal-2.pdf
have decent pictures and descriptions of how to get to the seals.
The links don't work anymore, does anyone have working links?
Tony
abmunro
Postby Fredjohn » Fri 08.12.2017, 00:03
abmunro wrote:The links don't work anymore, does anyone have working links?
Tony
Easy: go to PNM site and search for weather strips or look here
Brit car nuts website has moved I think: check at the bottom of his posts for the new link, also here
WikiLEC link: go to wikiLEC tab at top of page and then look for door glass weatherstrips or try this link
LEC solves another problem!!!!
Elan S4 DHC 1969
MB CLK 320CDi 2007
Boardman Team Carbon road bike
Evora 2010
VW T4 Campervan
Postby Brit-Car-Nut » Fri 08.12.2017, 06:37
The basic file (combined) is now listed in the Manuals site as well as Specky's guide to remove and replace the window motor.
http://www.lotusm100.com/manuals/Door-Card-Removal.pdf
http://www.lotusm100.com/manuals/Specky ... Repair.pdf
I tried to consolidate and relist any guides, manuals or other helpful articles I found that looked to be helpful.
Just go to http://www.lotusm100.com/manuals and look through the index.
Download Manuals Here
Postby abmunro » Fri 08.12.2017, 06:51
Thanks Guys!!
abmunro
Postby Steve A » Fri 08.12.2017, 14:00
I did the "Gordon conversion" years ago, as long as you use a good glue (I used Q Bond) it's not too difficult.
Even after all this time none of my tabs have come off.
Above is the Honda seal (via Jamie) which I'm currently working on.
