Custom Rear Hubs - Run 2
Postby Jeemy » Wed 29.01.2014, 17:19
The previous set of these went well, but took longer than it should have due to some personal issues which those who know about, know about.
The final set of the original 25 is now going on eBay and as such this won't really take place for a long time. When it does I will be able to get it from the factory to you, much quicker this time around.
So if you want a set of these hubs, please add your name to the list below. Once we hit 10 members the buy becomes possible, at 20, it becomes reasonably priced.
Here is the setup:
The Group Buy is for a PAIR of carbon steel rear hubs to fit the Elan; instead of a combined disc & hub, you have a common type hub which will take any brake disc suitable for a 4x100 setup, and so you can then pick your own brake setup. Thereafter instead of £300+ to replace the whole assembly, you only need to change out the brake discs (approx £20). It also allows you to put uprated brake kits on using bigger discs.
The hub kit works with OEM (using MDC266 discs or Apec), the PNM kits (although you need to be more careful with the disc choice or have 1mm skimmed off the disc face) and its my end goal to have the kit working with the HiSpec kit once more, but a custom part will need redesigned for that. By the time this is finished I hope to have that part already in play.
What you get:
*CARBON STEEL REAR HUBS*
Made out of carbon steel, milled with wheel bolt threads and a disc retaining thread. Inner bearings pressed in and sealed in an aerospace-grade chamber. Outer bearings to insert on fixing. 2 hubs, 2 bearings per side, per side.
Prices correct and inclusive of VAT at time of posting, this may change due to inflation/material costs when a production date is fixed. Prices based on 20 or more orders, its approx 15% more if people want to "go early".
Hubs (pair) £130.48
Bearings (pair, seals & fitting) £36
Shipping & packing £10
Total cost: £176.48
All prices include VAT at 20%. A VAT receipt can be provided.
- once we hit 10 people I will post up the current cost and those 10+ can decide whether to proceed
- once we hit 20 people we will start to look to close the list and commence production
- a deposit of £50 GBP is payable when the list closes
- production is realistically 7-8 weeks, but can be as little as 3-4 dependent on current loadings
- once the hubs are in my hands you pay the balance and they are shipped via insured courier
There will be no problems this time round with getting boxes, testing or anything else as I have double the amount of boxes I need and everything is tested already.
Realistically I would say this list will close after the summer and you'll get your hubs in time for winter maintenance. Please don't post your name if you are in a rush and a supply in Autumn won't do, or if its speculative, its not fair on others.
***Copy & paste from here downwards, adding or editing your name***
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Re: Custom Rear Hubs - Run 2
Postby novacaine » Wed 29.01.2014, 19:09
1. Novacaine
2.
3.
4.
5.
6.
7.
8.
9.
10.
I would definitely like a set
novacaine
Postby Jeemy » Mon 03.02.2014, 23:46
Novacaine now has a set. I believe Algirdas will want 2 but there is plenty of time.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby novacaine » Tue 04.02.2014, 15:40
Yes than you very much :)
novacaine
Postby pearman00 » Tue 04.02.2014, 19:41
1. Novacaine
2. Pearman00
3.
4.
5.
6.
7.
8.
9.
10.
pearman00
Postby Jeemy » Wed 05.02.2014, 13:31
1. Algirdas
2. Algirdas
3. Pearman00
4.
5.
6.
7.
8.
9.
10.
Just while I was correcting the list I put Algirdas on, have PMed him, there's no commitment just now anyway until we hit 10 people.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby ccb056 » Thu 27.02.2014, 02:46
1. Algirdas
2. Algirdas
3. Pearman00
4. ccb056
5.
6.
7.
8.
9.
10.
Looking for a set as well!
ccb056
Postby trig » Thu 27.02.2014, 16:44
1. Algirdas
2. Algirdas
3. Pearman00
4. ccb056
5. Trig
6.
7.
8.
9.
10.
trig
Postby Peter_W » Thu 27.02.2014, 17:40
1. Algirdas
2. Algirdas
3. Pearman00
4. ccb056
5. Trig
6. Peter_W
7.
8.
9.
10.
Peter_W
Postby johanvanboven » Mon 26.05.2014, 21:22
Hi,
Is this group buy still going on, or can anyone tell where those custom rear hubs are available at the moment?
BR. Johan
johanvanboven
Postby Jon » Tue 27.05.2014, 10:03
Can you confirm for a dunce - these hubs allow you to keep all the stock rear brakes as-is but just fit cheaper standardised discs?
If that is the case - then I'll take a set as it sounds like they pay for themselves when it comes to replacing the rear discs...
Jon
Postby Fredjohn » Tue 27.05.2014, 10:46
Jon wrote:Can you confirm for a dunce - these hubs allow you to keep all the stock rear brakes as-is but just fit cheaper standardised discs?
Quite correct Jon. You get purely a hub and bearings and then buy a standard "top hat" shaped disc to fit. The hubs with bearings costs £176 (can't remember pence!), but see above for conditions, and a pair of discs about £16-£20. I bought new Mintex discs from e-bay for £16. Fitted them this week: very asy job and in future I will only need to spend £16 to replace the discs instead of £200+
And Johan as far as I know this 2nd buy is still live: they are not available anywhere else unless a set is left over from the first buy (unlikely).
I have taken the liberty of adding both your names to the group buy: please remove them if I've over done it!!!
1. Algirdas
2. Algirdas
3. Pearman00
4. ccb056
5. Trig
6. Peter_W
7. johanvanboven
8. Jon
9.
10.
Postby Jon » Tue 27.05.2014, 11:38
Brilliant - thanks.
Oh, finally just to confirm they fit the S2??
Jon
Postby Fredjohn » Tue 27.05.2014, 13:06
Jon wrote:Brilliant - thanks.
Yes
Postby B_land » Tue 24.06.2014, 17:46
I'd like a set too. Please add me to the group buy.
B
EG S2
B_land
Postby Brit-Car-Nut » Tue 24.06.2014, 17:50
1. Algirdas
2. Algirdas
3. Pearman00
4. ccb056
5. Trig
6. Peter_W
7. johanvanboven
8. Jon
9. B_land
10.
11.
12.
13.
14.
15.
Postby Jeemy » Thu 26.06.2014, 16:29
When the list gets to 12 people I am going to check the current price for producing 10-12 sets of these. It can be done, I'll need to know if everybody on the list still wants, and/or is in a rush or no hurry at all.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby ccb056 » Thu 26.06.2014, 16:32
I'm still interested!
ccb056
Postby johanvanboven » Sun 13.07.2014, 21:38
I have the replacement Brembo Max brake discs, but no hubs to fit them.
The original discs are still fine, so no hurry.
johanvanboven
Postby BritAbroad » Wed 16.07.2014, 03:24
And me makes ten!
1. Algirdas
2. Algirdas
3. Pearman00
4. ccb056
5. Trig
6. Peter_W
7. johanvanboven
8. Jon
9. B_land
10. BritAbroad
11.
12.
13.
14.
15.
BritAbroad
Users browsing this forum: Bing [Bot] and 1 guest
