rockauto Water pump and belts
Postby Rice crispy » Mon 23.02.2015, 13:19
All,
I need to have my water pump and belts done this summer so intend to order them in the next couple of weeks. Im happy to do a group buy for all or some of the following and then forward them on.Please can you add yourself to the list and then I will get a final cost for postage to me based on what everyone wants, and then you can decide if you want to be included. The only additional costs will be onward postage to you which will be at cost and if we get stung with import charges then again i will share it based on what you purchased.
1. DAYCO Part # 95169K1 Dayco Import Timing Belt Kit without Seals £24.63 each
2. GATES Part # 41053 Water pump {#142, 512025, 559220} Includes Gasket £17.41 each
3. GATES Part # K060380 PAS NO AC {#25060380, 2570965, 4060380} K06-13/16" x 38-3/4" Micro-V AT Premium OE V-Ribbed Belt £3.77 each
4. GATES Part # K040270 Alternator {#25040270, 2570686, 4040270, K2704} K04-9/16" x 27-3/4" Micro-V AT Premium OE V-Ribbed Belt £2.23 each
1. Rice Crispy ALL 4
2.
I intend to close the list on 6th March
Rice crispy
Re: rockauto Water pump and belts
Postby dapinky » Mon 23.02.2015, 13:28
2. Dapinky, 2,3 & 4 (£23.41 + any extra costs)
3.
Postby daveiow » Mon 23.02.2015, 14:24
3. daveiow All 4 please
"live long and prosper"
Calypso Red 91se. Hispecs,PNM rear calipers,Samco's & BCN cables & SSK so far!(oh and a new hood and paint ....)
Alfa Sud 1.5ti long gone but not forgotten
daveiow
Postby Danevansgolf » Mon 23.02.2015, 15:39
4. Danevansgolf all 4 please.
Danevansgolf
Postby TrevorB » Mon 23.02.2015, 16:01
5. TrevorB all 4 please
Short shift conversion
HiSpec's
Wannabe Princess
Postby Rambo » Mon 23.02.2015, 16:27
6. Rambo - all 4 please
Postby Rambo » Mon 23.02.2015, 16:40
Just a couple of thoughts...
1) Is it better to go for the DAYCO timing belt kit with the new camshaft/crankshaft seals ?? Fiver extra. Advantages/disadvantages ??
2) Does the GATES water pump have the correct "rounded" teeth
Postby Brit-Car-Nut » Mon 23.02.2015, 17:24
Rambo wrote:1) Is it better to go for the DAYCO timing belt kit with the new camshaft/crankshaft seals ?? Fiver extra. Advantages/disadvantages ??
If you see excess oil around the back of the cam gear or the bottom of the Crank gear, then you need the seals. If you are not sure, then I suppose it is better to have them and not need them instead of need them and not have them. From Lotus, the cam seals are £7.30 each + VAT and the crank (oil pump) seal is £7.63 + VAT
Rambo wrote:2) Does the GATES water pump have the correct "rounded" teeth
I don't recall anyone commenting publicly on the GATES water pump but I consolidated a shipment for a LEC member that had 2 GATES pumps and one was OK and the other one was WRONG. Same part number on the box for both.
The only ones I know are right are the Airtex AW9220, the BeckArnley pumps were all correct per previous posts and the Bosch pump was correct but RA no longer offers it. I installed a Cardone pump on my car many years ago and it was OK. It now refers to WP718 which is different from Airtex which refers to WP717. The controversy started when GM changed the pump and belt for the GEO Storm 1.8L in late 1992.
I am sorry this doesn't exactly answer your question, but Rock Auto ships what they get from their suppliers and do not verify the correct pumps are in the box.
Postby novacaine » Mon 23.02.2015, 18:34
7.Novacaine - 1 and 2 please
novacaine
Postby mark675 » Mon 23.02.2015, 18:48
novacaine wrote:1. DAYCO Part # 95169K1 Dayco Import Timing Belt Kit without Seals £24.63 each
8. mark675 all 4 please
mark675
Postby alan e » Mon 23.02.2015, 18:59
Do they do a belt for cars with aircon fitted ?
Black 1992 M100
Austin 7 1932 box saloon
BMW X5
alan e
Postby Rice crispy » Mon 23.02.2015, 19:12
alan e wrote:Do they do a belt for cars with aircon fitted ?
Alan I believe so but I only looked up what I needed.
I'm happy to change things if everyone is in agreement. I thought the pump was verified ok bbut if there is another that is guaranteed ok I'm happy to go with it likewise with the seal kit ( hadn't seen anyone saying that they had needed to do them as well.
Rice crispy
Postby dapinky » Mon 23.02.2015, 20:07
Gates #K060415 is the one listed for A/C cars - £8.16 on rockauto.co.uk site. (or a GOODYEAR Part # 4060415 for £3.83)
Postby alan e » Mon 23.02.2015, 20:13
Thanks Dave
Black 1992 M100
BMW X5
alan e
Postby vinnie » Mon 23.02.2015, 21:02
vinnie all 4 please
vinnie
Postby epipete » Mon 23.02.2015, 21:20
8. Mark675 - all 4 please
9. Vinnie - all 4 please
10. Epipete - all 4 please
Postby Paul Alexander » Mon 23.02.2015, 21:30
11. paul alexander - all 4 please
Paul Alexander
Postby B_land » Mon 23.02.2015, 22:18
12. B_land - all 4 please
EG S2
B_land
Postby par » Mon 23.02.2015, 23:55
Dont want to mess up this thread but I am new here.
What is the advantage of this group buy over buying direct from RA? Is it just the saving on combined shipping offset with the onward postage in the UK?
I assume both will get hit for custom charges.
par
Postby epipete » Tue 24.02.2015, 00:01
Rock Auto are a U.S. firm and the item prices are cheaper than in the UK, however the postage impacts the cost, this can be negated somewhat by ordering in multiples and then dividing the postage costs up; there is a point though when the quantity being ordered reduces this benifit in which instance, as I understand it, several smaller orders can be used as a vehicle for reducing the cost again.
