Problems with Deliveries from Jeemy: Wishbones
Re: Problems with Deliveries from Jeemy: Wishbones
Postby GeoffSmith » Fri 09.11.2018, 01:09
Given the sensitive information being discussed about thousands of pounds worth of goods, paid for in full (some more than 4 years ago) but not delivered by "SVS - Specialist Vehicle Solutions" (struck off the Company House register on 3rd July 2018), visibility of this discussion has been limited to those with an interest in trying to find a way forward. If anyone else has parts that have not been delivered or information regarding SVS and/or Jeemy or the other two directors, then please send either dapinky or me a PM to gain access.
Postby GeoffSmith » Fri 09.11.2018, 20:45
Those given access should be able to see the discussion here.
Postby DaveP99 » Mon 18.02.2019, 14:45
Can I join this discussion? I was not aware of issues with this guy (only joined the forum recently) and have sent money for a pair of rear hubs. Three weeks later they have not arrived.
DaveP99
Postby Brit-Car-Nut » Mon 18.02.2019, 15:10
DaveP99 wrote:Can I join this discussion? I was not aware of issues with this guy (only joined the forum recently) and have sent money for a pair of rear hubs. Three weeks later they have not arrived.
Geoff will get back to you as soon as he can. If / when you get the hubs, be sure to check the press fit of the inner and outer bearing races. Some of his earlier hubs were machined off spec/size and the races just "fell" into the housing with finger pressure which is not good. They need to be an interference fit - needing to be pressed or drifted into place so the race doesn't spin with the bearing.
Postby DaveP99 » Mon 18.02.2019, 15:19
Thanks for the quick respnse. Both phone lines now unavailable (they were OK a week ago).
DaveP99
Postby Brit-Car-Nut » Mon 18.02.2019, 16:13
I am very sorry to hear that. Keep us informed with any changes or contacts with/from Jeemy, have you tried his cell number?
I will PM you the phone numbers I have for him.
