rubber ring for front wing!
Postby dapinky » Wed 05.02.2020, 15:36
Rubber grommit for inner wing air intake pipe (SE/S2)
Many (many many!) years ago I did a Group Buy for these rubber rings from SJ's (ended up with about 60 of the bloody things for distribution at Donington)....
... they were not as robust as the OE ones fitted to the cars, but better than a cracked or missing original.
Mine lasted about 5 years before showing signs of cracking - it is still intact, but looking a little past its best.
I intended to get another one, but it got put into the 'I'll do it one of these days....' basket and promptly forgotten.
Another thread has spurred me on to search the internet tirelessly for nearly 3 minutes, and i have seen the part advertised from "MGB Hive" for £3.
Obviously, to buy one leads to inflated P&P charges (as is standard!), but as with many sellers, they will offer a 'free P&P' subject to a minimum order.
Now, the astute amongst you will know where this is going (yes - to somewhere I never wanted to venture again!!!!).
Just to clarify, I have NOT spoken to the company, I cannot claim that the item is brilliant and will last forever - and I don't know if they have 1 unit or a box with 5 gross sitting on the shelf (you youngsters, and non-Brits may need to google what that means :lol: :lol: ).
I know that I can fit one in an envelope, but whether that envelope fits through the slot in the post office for a letter, large letter or small parcel, I cannot say. (well, I can have a good guess, as it won't be less than 5mm thick.... up to 25mm will be a 'large letter', and over that is a parcel.... so i would expect it to be a 'Large Letter'. Up to 100g attracts a postage charge of 83p and if it is over that, then £1.32.
Add in the cost of an envelope (not a lot) and I would expect it to be either a quid, or maybe a quid and a half (if over 100g).
Bulk orders charged at rate of postage, NOT necesarily as above. (or collect at Castle Combe for no postage option).
So.....
before i contact the company to see about stock availability, how many am I looking at? Is it just one for me, or does anyone else want a replacement? I will need at least 8 buyers to benefit from free delivery to my address.
Oh, and before it starts to get too complicated, I am prepared to post overseas, but would need to research costs for that, so it may be better to buy one in your own country if they are availlable for a reasonable cost...... Part number is AHA 5445.
1. Pinky
2.
3.
Re: rubber ring for front wing!
Postby donsladek » Wed 05.02.2020, 16:38
If I recall correctly, these rings are also used to isolate the fuel filler neck from the body- correct me if I'm wrong.
Another part number for these might be 280-105. These were used on MG Midgets and Austin Healey Sprites.
Moss Motors has these in the US for $3.99, but they require a $10 min order.
Don Sladek
Calypso Red '91 #37594
donsladek
Postby Tuga2112 » Wed 05.02.2020, 18:01
Dave.
have you got any pictures of exactly which part this is or the lotus part number and page in the parts manual to get a better idea ?
i suspect im gonna end up putting my name down to replace them in both cars, but im not 100% sure if your refering to the part that is supposed to protect the clam shell from the intake hose (from the intercooler to the plenum) vibrations or something else in that area of the car ?
PS, we be looking at CC collection if i dont see you sometime sooner this year
Postby clemo » Wed 05.02.2020, 18:29
1. Pinky
2. Clemo ( pick up at combe ... save postage)
3
clemo
Postby dapinky » Wed 05.02.2020, 20:04
Tuga2112 wrote:Dave.
Joao,
Lotus part number A100L0077F - item #55 on page 42.01A in the parts Manual
SJ part number = SJ100L0001 (listed at £10.25 each.... )
However - I have now been informed that the MG part *may* not be the best bet, as the inner diameter leaves a bit of a gap between the pipe and the grommit.
Does anyone have any definative information on this, or better yet, a picture of it in situ so I (we?) can make an informed decision on whether it is suitable, whether I speak to Steve Roberts for a deal, or whether we just leave it......
Postby TorqueHorse » Thu 06.02.2020, 06:28
donsladek wrote:If I recall correctly, these rings are also used to isolate the fuel filler neck from the body- correct me if I'm wrong.
In addition, I can run point on making a North America buy from Moss, if folks are interested. Just need 1 more person to hit the min spend. (Target end of Feb for buy?)
North America buy
1. TorqueHorse (x2)
2.
3.
'91 FED M100 -rolling resto
Postby Tuga2112 » Thu 06.02.2020, 10:06
1. Pinky
3. Tuga 2x
4.
Postby MPx » Thu 06.02.2020, 13:52
dapinky wrote:However - I have now been informed that the MG part *may* not be the best bet, as the inner diameter leaves a bit of a gap between the pipe and the grommit.
Not sure whether this helps much Dave as it seemed impossible to get a close up of the pipe/grommet "fit", but in my view its fine despite not being a super tight interference fit. There are no visible gaps with it in situ. This is a version of the MG/Sprite grommet bought in 2017 from ANG Classic Car Parts on scambay. As you can see it still looks fine but then its only 3 years old.
Without wishing to p**s on any parades....is it really worth all the trouble of a group buy for a less than a tenner item? Mine was £6:65 incl postage. Also there appears to be two threads/lists for this - or have I misunderstood (again!) ...
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Postby dapinky » Thu 06.02.2020, 15:40
Mike,
Thanks for the photo - it helps me to see what I'll get....... it looks fine to me.
As far as running it as a 'group buy', i fully accept that the items are 'only' £6 or so each, and thus the saving is less than a Costa Coffee (other chains are also available!) - but I see it more as a public service to those who want one, but (like me) keep putting it off for whatever reason. if I get a few people who I can help (especially if they are collecting in person), then we all win a bit.
It may well be that it isn't worthwhile to post them to USA (odd ones to EU isn't likely to be aproblem), but if there are a few people who want them over there, it may be better for them to do a GB of their own from a US supplier (or not!) - I'm just seeing if it is worth my while contacting the company to buy a few - it may well not be viable, but unless I look, I'll never know!
Postby Brit-Car-Nut » Thu 06.02.2020, 22:58
Not trying to kill the enthusiasm for the Sprite part, I want to point out that all of the cars have their HVAC air intake on the left hand side of the area behind where the induction pipe goes through.
Because the Sprite ring does NOT seal the to the pipe (and the seal at the body is also not very good), the potential to have the HVAC system pick up "contaminated" air from the engine compartment is highly possible.
Postby nicowalker1 » Thu 20.02.2020, 09:11
1. Pinky
3. Tuga 2x
4. Nick W x2 please
nicowalker1
Postby M100TURBOFR » Fri 21.02.2020, 16:03
Still a bit confused. At one point 3-4 weeks ago there were two posts re these rubber rings. I put my name down but obviously in the wrong one as I can't trace it any more.
I'd like to purchase one with postage to France in addition. I've added my name to your list. Payment will follow when required.
Thanks David
1. Pinky
3. Tuga 2x
4. Nick W x2 please
5. M100turbofr x 1 with postage to France
M100TURBOFR
Postby scotlan » Fri 21.02.2020, 16:21
1. Pinky
3. Tuga 2x
4. Nick W x2 please
5. M100turbofr x 1 with postage to France[/quote]1. Pinky
6. Scotlan (Tony)
scotlan
Postby Elanthrapist » Mon 24.02.2020, 00:54
1. Pinky
3. Tuga 2x
4. Nick W x2 please
6. Scotlan (Tony)
7.Elanthrapist x2 with postage pls. George.
1968 Elan S4 dhc (Now sold).
1973 Elan Plus 2 S130/5 [Lagoon Blue].
1994 Elan M100 S2[Medina Green].
Elanthrapist
Postby Lotussi » Wed 04.03.2020, 17:33
Hi there,
put me down for one of those please!
-I am not sure how this works with group buys...
Lotussi
Postby timhop » Wed 18.03.2020, 17:55
please put me down for 2x rings to post after receiving my payment.
timhop
Postby tigerdog » Sun 05.04.2020, 16:00
Count me in for one, please!
1. Pinky
3. Tuga 2x
4. Nick W x2 please
6. Scotlan (Tony)
8. Lotussi
9. Timhop x2
10. Tigerdog (with postage to California, please)
Postby NewLogik » Mon 06.04.2020, 16:12
Please add me in if it's still possible.
1. Pinky
3. Tuga 2x
4. Nick W x2 please
6. Scotlan (Tony)
8. Lotussi
9. Timhop x2
11. NewLogik ( with postage to Quebec, Canada)
NewLogik
Postby 431andy » Fri 01.05.2020, 08:08
1. Pinky
3. Tuga 2x
4. Nick W x2 please
6. Scotlan (Tony)
8. Lotussi
9. Timhop x2
12. 431Andy
431andy
Postby Quantum2001 » Sat 02.05.2020, 20:21
Please add me if possible, I replaced mine with one from SJs last year and it's all cracked already, not impressed.
Lotus Elan M100, Quantum Saloon, Honda CRZ, Hymer Eriba Jet
Quantum2001
