SLK Seat Mount Group Buy
I've been contacted by a few people ref a group buy on SLK seat adaptor plates.
You need to grind the rivets off the base of the SLK seat runners to enable them to sit fully down on the brackets.
Manufactured from steel, 5mm thick, laser cut,
They will be supplied naked, unpainted.
These mount the SLK seats as low as possible, you still end up slightly higher than in the standard Lotus seats so unsuitable for taller people.
You will need to supply your own fasteners to mounts to the car.
Would there be any interest at £40 a set of plates? I'll need a minimum of 3 people to commit cash before I can put in an order.
A 10%donation from the group buy will go to LEC funds.
