locked my keys in boot
Postby stevo » Tue 13.05.2003, 09:26
hi guys, <br><br>iv'e locked my only set of keys in the boot (trunk for you yanks). i know i shouldn't have put of getting another set cut but i didn't need them till now.<br><br>any suggestions please before i call out a lock smith and pay £££££££'s for 30seconds labour.<br><br>please dont post suggestions on the net, call me on 07789693443 or stephen64@hotmail.com.<br><br>HHHHHHHHHEEEEEEEEEELLLLLLLLLPPPPPPPPP.<br><br>stevo. ???
stevo
Re: locked my keys in boot
Postby Doug » Tue 13.05.2003, 09:41
Dude, what were you thinking . . . ?<br><br>I'll refrain from other belittling comments.<br>No way in there other than the key; put on a disguise and call the locksmith.<br><br> 8)
Postby Jon » Tue 13.05.2003, 09:41
<br>I think Lotus store the details of the keys and electronic gismos and can make new ones up without the originals.<br><br>Although I suspect that the time and cost might be probibitive (it took about a month to have a new alarm fob made after mine broke - although I am not sure how much of this was the dealer).<br>
Jon
Postby stevo » Tue 13.05.2003, 10:39
when i say i am locked out its because the girl i am suposed to be marrying next week has locked the keys in the boot. <br><br>im going to order a new lock and get it sent over night.<br>now im of to take a drill and a screw driver to my pride and joy.<br><br>D'oh, stevo [smiley=argue.gif]
stevo
Postby Sy V » Tue 13.05.2003, 12:51
Stevo<br><br>
<br><br>Chr*st! she only locked your keys in the boot mate...no need to take the drill and screwdriver to her!
Postby Dimitris_GR » Tue 13.05.2003, 12:56
It was the virginity belt key as well...  :P :P :P
Dimitris_GR
Postby chris » Tue 13.05.2003, 13:13
Stevo,<br><br>you shouldn't need to buy a new lock. I did the same thing half way up the french alps ! you need to hold the barrel with a pair of adjustable locking grips and rotate it. If it's a bit stiff you can use a screw driver blade in the key slot as well. There is only a small spring clip holding the barrel in place via two flats. I cant remember which way I rotated it though ! The barrel turns just enough to release the locking lever. Be very careful not to damage the paintwork around the barrel...use a cardboard template or some rag to protect it. You will need to straigten the spring clip afterwards (or purchase a new one).<br><br>Hope this helps.<br><br>Chris.
chris
Postby Sy V » Tue 13.05.2003, 13:28
Chris<br><br>Please phone Stevo (on his number above) about this.
Postby Elanbloke » Tue 13.05.2003, 14:25
Dimitris, actually I think the correct term is a 'chastity' belt! However, they are not used these days as we trust in the good behaviour of our ladies when we are away  ::)
Elanbloke
Postby rob » Tue 13.05.2003, 16:59
The NEW Vectra actually locks the keys in the car for you, as if you dont put the keys in the ignition after opening the car it automatically locks the car again after a certain time. [smiley=moon.gif] [smiley=moon.gif] [smiley=moon.gif] [smiley=moon.gif] [smiley=banghead.gif] [smiley=banghead.gif]
rob
Postby stevo » Tue 13.05.2003, 20:01
let this be a warning to you all!  Don't let your bird near your car.  If you have only one set of keys, get another set cut NOW!  Don't put it off like I did.........<br><br>Thanks for the reply at 1.13 Chris - unfortunately, at 1.12 I had taken a drill to the lock and drilled out the barrel.  Ah well.  Before I did this, I made sure I could get a replacement lock through my "local" dealer - Murray Motors in Edinburgh.  The locks have to come from Lotus direct.  All in, I won't see much change out of £100!!!!!<br><br> [smiley=bawling.gif]
stevo
Postby clemo » Tue 13.05.2003, 21:52
looking at the style of my ignition key it is a vauhall, just like what i had om my GTE, therfore  i would have a good look at some ageing old vauhall/opels as to where it was nicked/sourced from .... <br>£100 ! = Locked Out Twit Unhappy Stevo !!!<br><br>sorry mate somone had to do it  ::)
Jim Clark S2 - 1/13. The one with the Yellow spoke wheels . No 613 on dash (pushed in to factory in wrong order 615 on tub)
clemo
Postby Mike_H » Sat 17.05.2003, 20:40
The same thing happened to me a couple of years ago , I got a locksmith out to see if he could get into the boot and after 20 mins he gave up . Next he decided to take off the barrel from the passenger door , take it home and dismantle it . Came back the next day with a new key and a bill for £70 !! Anyway he said that the barrel was off a V. Carlton  glove box  ?
Mike_H
Postby Sy V » Fri 06.08.2004, 17:01
Oh I remember this thread...My how we laughed! ;D
Postby quiksilva » Fri 06.08.2004, 17:48
so did i until a month later when i did exactly the same bloody thing  >:(
The most successful people are those who are good at plan B.
1992 BRG Elan SE, 42k, Wilwoods, Killimanjaro & Daves short shifter, Oh & a bl**dy big grin.
quiksilva
Postby JETRO » Fri 20.08.2004, 18:50
You try the tennis ball thing ?<br><br> LOL LOL LOL<br><br> I think  Elans shouldn't have a key lock on boot, a lotus badge instead and a lever from inside near bonnet pull to lisft the boot!<br><br> [smiley=moon.gif] [smiley=moon.gif] [smiley=moon.gif]
Warning Warning Do not let your friends drive your Elan it will end in tears!
JETRO
Postby Game-on » Wed 15.09.2004, 08:55
I done this myself.....  :D<br>IT SUCK'S<br><br>Even in my youth i used to take away cars !!! I could not get into the boot of the Elan, well i did, i drilled the bastard out !<br><br>I then phoned around alot of key company's, these could not help me !!<br>I phoned lotus £40ish quid later and they send over the boot lock and two door locks as a kit.<br><br>What i am going to do is get a door popper !!<br>This will have a switch in the car, also work on the alarm key fob, push the button it pop's the boot open !!<br>I am also taking the key lock out of the boot, so you will only be able to open the car either from the alarm or a hidden switch in the car !!<br>I am also doing the popper thing with the doors, as i lose keys all the time. <br><br>I will post them company on project thread if anyone want to look  ?<br><br>Game-On  ;D
Game-on
Postby clemo » Wed 15.09.2004, 09:37
i don't have that problem of locking keys in boot ...<br>thats coz i've got an electronic boot release...<br><br>done that mod , now on to the electroinc petrol flap..<br>only one more switch on the dash to use ...<br><br><br> ;D
clemo
Postby grahamec » Wed 15.09.2004, 11:15
[quote author=clemof1 link=board=body;num=1091808113;start=15#18 date=09/15/04 at 01:37:31]i don't have that problem of locking keys in boot ...<br>thats coz i've got an electronic boot release...<br><br>done that mod , now on to the electroinc petrol flap..<br>only one more switch on the dash to use ...<br><br><br> ;D[/quote]<br>Clemo<br>You told a few of us at the Lakes how you did this, do you fancy doing a write up for the forum as it seems a worthwhile mod.<br>Cheers<br>Grahame
grahamec
Return to Historical Events Archive
