Idler/tensioner bearing part numbers?
Postby Dico » Wed 04.01.2006, 22:01
Does anyone have the above part numbers for just the bearings i.e. not the 'complete' item as supplied by lotus.
I imagine it will be a lot cheaper to have the bearing pressed in and out rather than spend £100 +.
Cheers :)
Postby Rogerf » Thu 05.01.2006, 00:02
Hi Dico,
i'm looking at going this route myself.
Spoke with Sj's recently and they quoted me £187 inc vat for cambelt, idler pulley and tentioners.Then there is the question of whether to change the waterpump while its stripped down.
Sorry don't now part no.
Roger.
Rogerf
Postby Dico » Sat 07.01.2006, 23:13
Doc has kindly taken the following numbers for me/us.
Tensioner: 6006DWAX
idler: 60STD61DWAX
Anybody know who is likely to stock these parts?
Postby Paul.P » Sat 07.01.2006, 23:22
If you get the bearing pressed out, there will be numbers on it, & any bearing supplier should be able to get you one.
Look at what I have found!!!!!!!!!
Postby kmckmc » Wed 26.07.2006, 12:07
Hi,
I just bought a DAYCO
I am about to replace my Elan's timing belt and related parts.
I came across this DAYCO item:
I bought from www.rockauto.com
look in Isuzu/1991 Impulse RS/Engine/Timing Belt Component kit
DAYCO part# 84103 Timing Component Kit
This kit consists of 2 items.
1 unit of 85184 , which is the belt idler
1 unit of 85276, which is the belt tensioner
ALL for US$ 40.79 HOW ABOUT THAT.
Elan M100 S2
kmckmc
Dayco timing kit
Postby stevieg8571 » Mon 23.04.2007, 18:18
Hi,
I tried buying one of the Dayco timing kits last week at both Autozone and Kragen but both couldn't find those part no's but said that it's been changed to TTIK103 and was a Goodyear item.
It only cost $55.76 so have purchased myself one for my forthcoming belt change day, (If I ever manage to escape the U S and A that is!)
Steve
stevieg8571
Postby kmckmc » Tue 24.04.2007, 11:07
HI,
I just checked the rockauto.com website. It still is offering this DAYCO package for $40.79.
I know rockauto.com ships internationally and takes PAYPAL payment.
Cheers,
Elan M100 S2
kmckmc
Postby theelanman » Tue 24.04.2007, 12:29
dico
I just bought the whole lot
I went for the more expensive as theyre so cheap :shock:
Engine : Timing Belt
GATES Part # T169 {Automotive Timing Belt 1" x 50 3/32" (159 Teeth)}
Interference engine application $17.14
Cooling System : Water Pump
BECK/ARNLEY Part # 1312115 $47.79
Cooling System : Water Pump Gasket
BECK/ARNLEY Part # 0394100
Water Pump Gasket, 1 Per Car $2.00
Engine : Timing Idler
GATES Part # T42001 {Timing Belt Pulley Steel Smooth (60mm x 10.4mm x 31mm)} $48.79
Engine : Timing Belt Tensioner
GATES Part # T41027 {Timing Belt Tensioner Steel Smooth (60mm x 10.5mm x 30.5mm)} $52.79
see here.... http://www.lotuselancentral.com/forum/v ... 4&start=20
by the way if you get the water pump you get a gasket with it....hey but for the sake of $2 I'd rather have one than not......
took rosk autos 4 days to get the parts to me...and they took paypal
Postby Dico » Wed 25.04.2007, 17:26
Cheers G
I've purchased two of each since I made the initial post in Jan 06 :)
It seems its the way to go, purchasing overseas. Has the tax man stung you yet? :evil:
Hope your head gasket change goes well. Make sure you wear your lucky yellow trainers 8)
Postby theelanman » Wed 25.04.2007, 17:31
dont know what you mean....Ive bought another 2 pairs...... :-D
Postby Dico » Wed 25.04.2007, 17:56
Can't bloody read that! :-D
Postby theelanman » Wed 25.04.2007, 19:04
well go over it as if you were cutting and plasting :shock: :-D
Postby Dico » Wed 25.04.2007, 20:14
Cutting and plasting? :-D
Postby Specky » Sat 01.12.2007, 21:21
Cheers Gareth...
Just ordered... your list $150 ish for the expensive stuff... :-D
Yep..... it's got cheaper....
and with the value of the dollar... :-D
and splashed out on the fed ex tracking option...
In fact the postage 90 odd dollars..
So all in all... :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D
Postby davidjt » Sun 02.12.2007, 00:08
Sadly, you'll need to budget for the VAT (+ a collection fee) on top; the bill from FedEx arrives about a week after the parts. Still cheaper than SJs, though. :D
davidjt
Postby theelanman » Mon 03.12.2007, 11:41
davidjt wrote:Sadly, you'll need to budget for the VAT (+ a collection fee) on top; the bill from FedEx arrives about a week after the parts. Still cheaper than SJs, though. :D
Ive never had one......
I suppose it depends on if it gets caught in the 'import' net :-D
Postby dapinky » Mon 03.12.2007, 12:28
Nor me :lol:
It all seems to be a bit of a lottery on which carrier is used for the trans-atlantic leg of the shipping.
Hopefully, at this time of year they'll have more to worry about helping Santa get stuff round the world!
Postby rip » Mon 03.12.2007, 12:46
I'll know the answer to that in a few days. I ordered a load of bits from Rockauto last night.
Jack.
Postby Specky » Mon 03.12.2007, 14:25
I've got two shipments coming in... :shock:
First one only took 4 hours to clear Stanatead...
I've waited weeks to get stuff through customs and then had to bribe the official to release it...
Gotta love corrupt countries... infact most of the countries customs are bent
I can recall a certain sales pitch for the Kestral US101...
Long story short... US customs impounded our Aircraft.. but only after Hilary Clinton had her go.. :wink: .
Anyway what will happen.. I'll let you know...
Postby Specky » Thu 20.12.2007, 16:08
No customs bill... :-D
Have a discount on me...
Thank you for being a www.RockAuto.com customer! To show our
appreciation, we have a special discount for you.
Your discount code is:
868702767772
Here's how to use it:
* Enter your code in the "How did you hear about us" line of the
shopping cart.
* If you are using our traditional HTML catalog, please click the
"Set" button to the right of the field.
* Your discount will automatically appear, subtracted from your order
total.
**NOTE: We sometimes get calls from people who put the word "discount"
in front of their code and do not get the discount. Please enter ONLY
the discount code, no other words or numbers.**
The discount takes 5% off our already-low prices, and there's no limit
on order size or the number of orders. Use the code for your next
order, and share the code with friends, neighbors, relatives, the guy at
the corner garage--anyone you know who works on cars or trucks.
This discount code expires on February 19, 2008; so don't wait!
REMEMBER THE WIKI!
