DavidElena wrote:2. I read about the Elan scan, in this case where I can't energise the circuit will Elan Scan be able to give me any diagnostics?
DavidElena wrote:3. If it does need to be replaced is it a part that can
just be ordered and plugged in or does it need specialist set up by Main Dealer?
DavidElena wrote:4. I'm wondering whether I should take the opportunity to upgrade the chip if I have to replace the unit, reading the threads I see everest is popular, are there any major problems with upgrading the chip?
DavidElena wrote:5. Reading through the threads I see ESM (Alan?) seems to be the ECU/Chipping Expert and the main supplier for the upgrade chips.
DavidElena wrote:The original problem was a sudden flat battery, fine in the morning, completely dead in the afternoon (lights not left on or anything obvious). Can a faulty alternator draw current when the engine is switched off?
ESM wrote:The autoelectrician didn't earn his money then....
ESM wrote:Check that the boot light isn't staying on - it is frequently is the cause of battery discharge
DavidElena wrote:I'm intrigued to find out what happens when you ignore the 'do not try to repair' label, it could be like the bit from Raiders of the lost ark when they open the ark.
