Engine rebuild project following blown piston
Postby paulwatkins » Thu 11.01.2007, 08:57
Let's have some pics of your nice shiny head for Stef!
I'll give it a really good polish this weekend and post some pics!! :shock:
Now the jigsaw begins...don't leave it too long or you'll forget where all the bits go and get left with a jam jar full of "spares"!
Dave, I hope you remember how everything goes back! :roll:
Seriously though Neil, we were very methodical - everything has been kept in sets and placed in labelled envelopes as they were removed.
As soon as I receive the seals from kmckmc (which should be early next week) I (we including Dave :wink: ) can start putting the valves back in and the rebuild start in ernest.
paulwatkins
Postby GeoffSmith » Thu 11.01.2007, 14:30
paulwatkins wrote:ernest.
That's a bloody funny name for a car!
Postby paulwatkins » Thu 11.01.2007, 15:24
Ernest is banana-car!
:banana:
Or is it Ernie is banana-man? :roll:
paulwatkins
Postby GeoffSmith » Thu 11.01.2007, 16:30
paulwatkins wrote:Ernest is banana-car!
gray as well! See here.
Postby GeoffSmith » Thu 11.01.2007, 16:31
Thinking about it, Ernie's milkfloat is faster than Ernest at the minute (if you don't understand, ask crumbly Dave) :-D
Postby paulwatkins » Thu 11.01.2007, 17:06
You're right Geoff, I'm not old enough to know about Ernie who drove the fastest milk float in the west! doh! I've been busted! :shock:
message to moderators - is it possible to ban certain people from a thread for hi-jacking with off-topic comments? :-D
paulwatkins
Postby GeoffSmith » Thu 11.01.2007, 17:44
paulwatkins wrote:message to moderators - is it possible to ban certain people from a thread for hi-jacking with off-topic comments? :-D
Postby paulwatkins » Thu 11.01.2007, 17:51
:offtopic:
paulwatkins
Postby Sy V » Fri 12.01.2007, 06:37
paulwatkins wrote:...message to moderators - is it possible to ban certain people from a thread for hi-jacking with off-topic comments? :-D
Bottom line is - yes.
But why should you be different - he does it to everyone else's threads. :roll: ;-)
LEC Godfather
Postby paulwatkins » Sat 13.01.2007, 11:13
Pics of cylinder head following re-seating work and quick clean-up.
paulwatkins
Postby paulwatkins » Sat 13.01.2007, 11:17
All the parts that I was waiting for have arrived this morning!
Also, just picked up the cam-cover from the body-shop - Now it's Banana Cam-cover!
paulwatkins
Postby Enright » Sat 13.01.2007, 11:32
That looks like excellent work Paul - you've got the foundation of a great job coming along there.
The only thing I would question would be whether you would have been better off sticking a wire brush attachment to a drill down the exhaust ports before grinding-in the valves. It's still not too late to do it, just be careful that you don't catch the newly ground valve seats and bog-up your (OK Dapinky's!) previous work.
On the same subject, did you spin up each valve (especially the exhaust ones) in a drill to remove the excess carbon deposits?
Oh and I nearly forgot: BANANA cam cover?!? :? :lol:
The finished result will be a site to behold - I'll reserve judgement on that one til I see it! You're not doing yellow Samco's too are you? Should make it EXTREMELY easy to see any leaks!
Postby paulwatkins » Sat 13.01.2007, 14:48
Thanks for the suggestion Neil. Job just done! Used the wire brush attachment on my drill via the manifold end, then used a dremel to carefully do inside the valve area being careful not to touch the newly ground seating. Then used a compressor to blow the area clean. Also did the same to the exhaust manifold - well, the best I could.
Again, thanks for the suggestion, I will do this.
BANANA cam cover?!?
Just for you Neil, here is a pic of how the cam will sit within the engine bay when the re-build is complete. I know its not an exact colour match, but I think it's looks pretty good and should be fine when everything is complete. What do you think guys?
paulwatkins
Postby GeoffSmith » Sat 13.01.2007, 15:21
You should be very pleased with your work Paul. The silver of the block looks really good. Are you going to have Ernie ready for Donny?
Geoff
Postby paulwatkins » Sat 13.01.2007, 16:18
That is the plan Geoff. I want to be part of the mass convoy! :D
I need to start making some progress - I want Ernie to be run-in in time for Donny.
paulwatkins
Postby Enright » Sun 14.01.2007, 00:52
It's looking spanking under there! I think you're right - the shade's a bit off, but with the rest of the stuff re-connected you should be OK.
While you've got the turbo and heat-shields off and accessible, I'd get buffing if I were you!
Oh and I couldn't agree more with Geoff - the silver is spectacular.
Now, isn't it about time you changed your avatar to something a little more appropriate? I have found a few samples of some which might tickle your fancy...
Postby paulwatkins » Sun 14.01.2007, 17:36
LOL, thanks for the avatar suggestions Neil!
The heat shields and turbo will definately be buffed up prior to refitting. I'm not sure how well the sheilds will come up though - they were a little bit ropey - I'll have to see how it turns out.
paulwatkins
Postby Doc Fizzix » Tue 16.01.2007, 16:11
For those who know, should you re-torque the head bolts at 500 miles after a rebuild? I am sure this info will be helpful to all but I do not see anything in the manual.
Doc Fizzix
Postby paulwatkins » Tue 16.01.2007, 16:26
Doc, I've had a quick scan through the maintenance manuals, and I can't see anything in them either.
But, seeing as it is a pretty straight forward job to do, it wouldn't harm to check them at say 500 miles like you suggest.
Is it something you will do Doc?
paulwatkins
Postby Doc Fizzix » Tue 16.01.2007, 17:23
paulwatkins wrote:Doc, I've had a quick scan through the maintenance manuals, and I can't see anything in them either.
I am at that point and I just do not like the idea of pulling the valve cover and then cracking the head bolts loose. In years past with the cars I worked on you almost had to and the manuals told you to do it but before I do it on my new Elan motor I would like some input.
I will be spending this coming weekend goinng through the whole motor and double checking everything now that I have 500 miles on her
Doc Fizzix
Return to Engine
Users browsing this forum: Bing [Bot] and 2 guests
