Porting the wastegate
Postby Sy V » Sat 20.01.2007, 10:32
Hmm, it's good but perhaps a little generic?
I don't think we suffer from the 'flat surface for the gate to close on to' syndrome, post porting either.
LEC Godfather
Postby Enright » Sat 20.01.2007, 10:56
Porting the wastegate itself is no problem.
In the same way that, for example, honing your engine bores is no problem.
The real problem is getting all of the associated cr@p out of the way to gain access to the job in the first place!
This is made worse by the fact that most of it is being shifted for the first time in 15 years, and is in precisely the area that gets the most ferocious heat cycles.
You will find fasteners have all settled and got baked hard in place, and are often very difficult to gain decent access to. When you try to disturb many of them, they have a much higher risk of just shearing.
I wouldn't put anyone off from doing the job if they've already got a "have a go" attitude, methodical approach, and a sense of humour! Just so long as they don't absolutely rely on their car on a daily basis.
In fact I would recommend it in any of the following circumstances:
If the engine is out or turbo is off, as preventative maintenance - taking advantage of the extra room to work.
If you are experiencing fuel cut-offs caused by overboost or "boost creep" (indicated by fault code 34) after recently having had a new exhaust fitted, as a cure. The lower bolts from the pre-cat to the exhaust downpipe are some of the worst, and if Kwik-Fit has already tackled these for you, you're laughing!
This is why it will be so much easier for Paul - he already has room to work, and if any bolts or studs snap then they won't take his car off the road, cos it already IS off the road!!! :-D
It is a job that you can do with some fairly basic hand tools (socket sets and spanners) and patience, but which you would pay a garage hundreds for.
It's less complicated than, say, changing a cylinder head gasket. You just have to be realistic that there is very little room to work, and you're probably going to end up with red knuckles and blue air.
When I have time to go back through the Stiffy thread, I can certainly edit and combine my posts into one (perhaps in a Word document with pictures added in the right places), and send it to Sy (or Liz).
For me the important (and scary) thing was all the process leading up to the porting job. This was really just fear of the unknown, and if I can help dispel that for others, then jobs-a-good-un! :D
Postby Sy V » Sat 20.01.2007, 13:01
:goodposting: Fantastic ethos too Neil, thanks.
LEC Godfather
Postby GeoffSmith » Sat 20.01.2007, 13:29
:agree: Well done Neil. :smt023
Postby dapinky » Sat 20.01.2007, 14:02
lotuska wrote:I don't know if this is of any help, but it does have some good pictures...
www.aaroncake.net/rx-7/s4wastegate.htm
A welder after my own heart!
Solid as a rock, but never going to win a beauty contest :D
Postby Dave M » Sun 21.01.2007, 05:35
Dave M
Postby isuzuimark » Mon 22.01.2007, 16:35
What is your boost creeping to? As long as your not hitting fuel cut or knocking I wouldnt worry about it. these ecm's run pig rich. if its staying under 14 psi just set the boost to 14 and no more boost creep, just more boost.
isuzuimark
Postby paulwatkins » Tue 23.01.2007, 19:58
Here are some before and after pics of the wastegate opening.
I used the conical shaped bit to open up the hole to approx 21mm diameter. I then used the 'lollipop' bit to take away some burrs and form a slight chamfer on the opening.
It's a very straight forward job once the turbo is out of the car and on the workbench. The hardest part o fthe job will be removing the damn thing from the exhaust manifold!
paulwatkins
Postby GeoffSmith » Tue 23.01.2007, 20:39
isuzuimark wrote:What is your boost creeping to? As long as your not hitting fuel cut or knocking I wouldnt worry about it. these ecm's run pig rich. if its staying under 14 psi just set the boost to 14 and no more boost creep, just more boost.
Steve,
The problem that many of us are having is that we are getting boost creep and fuel cutoff after installing Peco 2¼" exhausts - I've got an impression of my steering wheel on my forehead to prove it. :evil:
Postby GeoffSmith » Tue 23.01.2007, 20:42
paulwatkins wrote:It's a very straight forward job once the turbo is out of the car and on the workbench.
Thanks Paul! :evil:
What gaskets will I need for when you and Dave come around to show me how to do it? :wink:
Geoff
Postby Enright » Tue 23.01.2007, 22:40
None.
Yes seriously - they're all re-useable in that area.
Postby GeoffSmith » Tue 23.01.2007, 22:43
:shock: You mean the moths can stay leather bound? :-D
Postby Enright » Tue 23.01.2007, 22:50
Not quite.
If it's at all possible, see if you can get an extractor to remove the exhaust manifold studs.
If I'd had one of those it would have made the whole job a lot easier as it would save having to unbolt the turbo from the manifold.
Postby paulwatkins » Wed 24.01.2007, 08:38
Geoff,
when I removed the cylinder head initially, the exhaust manifold was still attached. It remained attached up until the day Dave came around to extract the valves.
I was a bit dismayed when he said that it had to come off in order to get the spring compressor to fit. The threads and nuts looked as though they were rusted solid and had not been touched for the 15 years they had been there! I thought they would never undo.
BUT, with a very small spray of WD they all came off with no problem at all!! I couldnt believe it! I'm sure Dave would agree with this.
If you do have problems with the nuts and decide to take out the turbo still attached to the exhaust manifold, you will have to remove the dip stick guide and probably the bracket on the front rhs of the engine to gain access to the end fixings.
Also, if you do remove the exhaust manifold, I have a spare gasket you can have (if you dont want to reuse the exisitng) :D
I had more problems removing the turbo from the exhaust manifold. IIRC the is one particular thread/nut that is very difficult to get to (even with the unit out of the car).....and that was my 'theres always one bastard' fixing!. :evil: It was really tight all the way to the end. I decided to renew all the threads and nuts after that little episode!
paulwatkins
Postby paulwatkins » Sun 28.01.2007, 10:00
I have just re-fitted the turbo to the exhaust manifold, and the thoughts of 'how the hell am I going to get a spanner on that" came flooding back.
Bear in mind that this was done with no PAS pump in place (and if you got it, the A/C pump which I think is in the same-ish location), the car up on axle stands in the garage, heat shields previously removed, all new studs and nuts and copper grease! :shock:
On the up-side, all of the nuts ARE do-able in some way or another. using a selection of different types of spanners - ring, open end, stubby, offset etc.
BEFORE starting the removal of the turbo, I would strongly recommend you to purchase a good selection of different types of 14mm spanners.
ALSO, I would recommend that you begin to routinely spray all the fixings with release fluid (WD40) some considerable time before you plan to start the project. Maybe even consider some form of applying heat to the nuts (may be tricky on a few of them though)
Good luck........may the brute force be with you! :-D
Cheers, Paul
paulwatkins
Postby Dico » Sun 28.01.2007, 13:21
Don't panick when you first start the engine up and the copper slip starts to smoke......as I did :?
Postby Russc » Fri 17.08.2007, 12:57
Looks like i will have to undertake this project in the near future, i can see a good few references but the thread that had the write up has gone :( :(
Anyone got one hanging around??
Russc
Postby GeoffSmith » Fri 17.08.2007, 16:17
Russc wrote:Anyone got one hanging around??
If there is such a thing, could you make sure I get a copy and we'll get it Wiki'd?
Postby Russc » Fri 17.08.2007, 19:31
Enright13 wrote:When I have time to go back through the Stiffy thread, I can certainly edit and combine my posts into one (perhaps in a Word document with pictures added in the right places), and send it to Sy (or Liz).
Neil, did you ever get round to this?
Russc
Postby Enright » Fri 17.08.2007, 19:42
No. :oops:
