Pinky II
Postby Dave M » Mon 20.11.2006, 17:03
:agree: :clap:
Dave M
Postby Monty » Tue 20.02.2007, 19:04
So the Stock seats have now been replaced with Cobra Monaco S seats using the original runners and spacers removed to give a better driving position. Since there a hard base with a bit of foam and with the dampers settings set quite stiff for trackdays u can certainly feel those bumps, feels more like an Elise now LMAO :lol:
Since my temp gauge has always read low 1/8th on the old gauge and now on the lockwood one`s the needle only just moves of bottom, so fitted a Halfords £5.99 thermostat. Anyways seems to off made no difference but at least it`s got a new one fitted.
More pic`s and fitting guide here
lotuselancentral.com/forum/viewtopic.php?t=8986&start=20
Cobra seats
Picture 033.jpg (49.96 KiB) Viewed 7914 times
Cobra seats
Picture 031.jpg (51.82 KiB) Viewed 7914 times
Postby GeoffSmith » Tue 20.02.2007, 19:06
Monty wrote:Since my temp gauge has always read low 1/8th on the old gauge and now on the lockwood one's the needle only just moves of bottom, so fitted a Halfords £5.99 thermostat. Anyways seems to off made no difference but at least it's got a new one fitted.
You can get an accurate figure for coolant temperature with ElanScan.
Postby Paul.P » Tue 20.02.2007, 19:08
Well done Monty, really admire your ingenuity when it comes to doing things like this !, might have to put you & old foxy up for weekend when change body, free grub & beer , what do you say ?
Postby Monty » Tue 20.02.2007, 19:12
Cheers Geoff,
The last time i did ES run the temp was fine IIRC it was around about 80 :? think it`s just the gauge has a shite reading :roll: BTW what should be the temp normal on a normal run?
Postby GeoffSmith » Tue 20.02.2007, 19:14
85° if you've got an 85° 'stat!
Postby Dico » Wed 21.02.2007, 16:28
Paul.P wrote: might have to put you & old foxy up for weekend when change body, free grub & beer , what do you say ?
I'll come down for the grub n beer, I'm very good at supervising 8)
Monty, make sure you get some bulky cushions for the France trip :shock:
Postby Monty » Wed 21.02.2007, 18:03
Got the AB shortshifter fitted today and set to the shortest setting, been out for a quick spin and feels the same as Dave`s version. The advantage to Daves (v2) is it`s in Stainless steel, cheaper, easy to fit and should be able to fit without removing the gear selector. But both are well engineered. It`s a must have on the M100 upgrade list :-D
AB Shortshift & stock selector (top)
Daves Shortshift (V1)
Picture 006.jpg (65.68 KiB) Viewed 7874 times
Postby Monty » Thu 01.03.2007, 16:44
Got the Harness fitted today :-D
Passenger side is a Sabelt 4 point bolt in type which i got of ebay awhile ago cost of £20 :-D It`ll do for Dico :wink:
Drivers side was from Hanger 111, Luke 4 point wrap around (eventually i`ll put the same one on the passenger side). The shoulder straps wrap around the Roll bar/hoops. Best thing about this one each part is seperate and i can pull them through the holes when i just want to use the seat belt.
Sabelt Harness
Picture 003.jpg (48.79 KiB) Viewed 8053 times
Luke Harness, Hanger 111
Luke 4 point Harness from Hanger 111.jpg (49.05 KiB) Viewed 8054 times
Postby dapinky » Thu 01.03.2007, 17:03
Looking good :smt023
(I'm sure you're trying to copy my Dolly.....same seats.....same Luke harness......what next? upping the power output to the same as mine :wink: )
Postby Monty » Thu 01.03.2007, 17:24
dapinky wrote:Looking good :smt023
LOL
I did have a Dolly many years ago IIRC 1500cc, it was painted in red led paint by the previous owner but had no welding done on her and had all the old MOTs, let my Auntie use it for a couple of months and she went and blown the engine (no oil :roll: ) Then it went oto the scrappers :cry:
Those harness aren`t cheap, but i will get one for the passenger side for Dico for when we go france in May.
Postby Sy V » Thu 01.03.2007, 17:26
Nice work Jay.
I see Pinky's living up to her name:!: ;-)
LEC Godfather
Postby dapinky » Thu 01.03.2007, 19:29
Monty wrote:Those harness aren't cheap, but i will get one for the passenger side for Dico for when we go france in May.
I got mine from Peter Lloyd (Rallying) over in Welsh Wales.
They were the cheapest by a few quid to anywhere else. 2 harnesses + the eye-bolt fittings and strengthening plates for just under a couple of hundred quid delivered (2 days) - it was a couple of years ago, but looking on there web site HERE they're up for £105 inc VAT at the moment.
Postby Doug » Thu 01.03.2007, 21:46
Nice work, Jay.
Just be sure those shoulder straps are mounted to the right thing and at the right height.
Also be careful where that little dagger on the bottom of the harness buckle presses :oops:
I guess you seat still moves, but I was about to laugh at what I see as a small fire extinguisher behind your seat. My dad luckily had a fire extinguisher in his Corvette in the 1970s cause one day his rear axle bearing went out and started a little grease-type fire. He only found out when a driver pulled up beside him and said, "hey buddy, your car's on fire!" He pulled over and was able to extinguish it with his extinguisher. The repair was pretty simple after--otherwise, Fibreglass cars can really burn (cue that picture of the Gallardo in flames).
Moral of the story = have an extinguisher in the boot or even better where you have your for track use!
Postby Rambo » Thu 01.03.2007, 23:00
Doug wrote: Fibreglass cars can really burn (cue that picture of the Gallardo in flames)
http://www.youtube.com/watch?v=2o_UV-iMDJ0&eurl=
Postby Ekapol » Thu 01.03.2007, 23:21
Anybody knows how many yellow Gallardo are there around SF Bay. It might be the same one that waited and then zoomed passed my car on highway 280 :?
Ekapol
Postby Monty » Fri 02.03.2007, 00:11
LOL, i was thinking the same when fitting it, now if that was Stevo and his Stiffy might be a different story :lol:
You guys know how to cheer somebody up :roll:
Postby Doug » Fri 02.03.2007, 08:36
saw this in someone's signature elsewhere -- knew it would be perfect for this thread . . .
Postby GeoffSmith » Fri 02.03.2007, 10:46
Doug wrote:knew it would be perfect for this thread . . .
:smt017 Come again.
Postby Monty » Fri 02.03.2007, 19:21
:smt017
You calling my Thread W**k :twisted:
Hey Doug you know u can get put away with thoughts like that :roll:
