Replacement seatbelts
Postby rival » Tue 20.03.2007, 23:25
Another question (blame the stand at Donington for reminding what a useful resource this is!).
My seatbelts don't retract that reliably and I want to replace fully rather than take any risks. Prices at a couple of Lotus dealers are around £150 a pair. The last seatbelts I bought and fitted (about five years ago) for my old Spitfire were £50 a pair, so I was wondering (yet again :wink:) whether anyone had any money saving tips.
Some of the other threads mention that the female end is the same as some Nissan set, but I couldn't find anything about whether there was a standard GM set that would fit the Elan SE.
Any ideas?
James
rival
Postby Specky » Tue 20.03.2007, 23:29
Try HERE
Postby rival » Tue 20.03.2007, 23:36
Thanks Dave.
So £140 for the pair at Donington was good value after all. Damn.
I assume fitting is straight forward enough. I couldn't find a guide on this site.
James
rival
Postby Specky » Tue 20.03.2007, 23:43
Tried HERE
Postby Specky » Tue 20.03.2007, 23:45
So does that mean your old ones are up for sale.. :D
I'm intrested
Postby Ghost » Mon 09.04.2007, 16:07
I have just replaced my seatbelts, as the old ones did not retract without a lot of help and I was worried that they would not pass the MOT.
I sent my original seatbelts to F.D.T.S. Ltd (www.fdts-seatbelts.co.uk) after a phone call to Sue Taylor (01932-342043) to explain what was needed.
She supplied two new Autoliv retractors with webbing and fitted the original buckle and loop, which is fixed to the B post.
The belts were returned the same day they arrived at F.D.T.S. and the cost was £45 per belt + P&P + VAT.
The service and help from Sue Taylor could not be be beaten, and I would recomend them to everyone!
Steve
Spending the kids inheritance
Ghost
Re: Replacement seatbelts
Postby Specky » Mon 09.04.2007, 16:34
Ghost wrote:I have just replaced my seatbelts, as the old ones did not retract without a lot of help and I was worried that they would not pass the MOT.
Steve
Did all that work and not dun mine yet...and I must.. :(
I'm trying to find a spare set.. to try and get a rolling exchange going
Any chance of a write up on how easy they were to change on the car
Also is there an Autoliv part No on the retactor...
The reason is:-
I know the Springs are made in the UK... shipped to Australia...fitted to retractors.... then shipped here... but Autoliv are keeping stum...I don't think they know it's used on our car... So I'm trying to find the number for the spring eventually..
Postby Ghost » Mon 09.04.2007, 16:59
The replacement of the seatbelts is very easy, which is unusual for Lotus!!!
After removing the trim from the 'B' post, a 17mm socket is needed to remove the 4 bolts that hold the seatbelt.
In my case the most difficult job was removing the trim, as my car had been retrimmed with excessive use of black gunky sealant which stuck to everything!!
It took about one hour to remove the original belts, and roughly the same time to install the new belts and refit the trim.
The Autoliv retractors are preloaded with webbing, and F.D.T.S. remove the belt loop that fixes to the 'B' post and fits it onto the new belt before fitting the buckle.
That is the reason I sent my old belts to F.D.T.S., but I suppose you could just send the belt loop and buckle from your old belts.
I cannot remember seeing an Autoliv part number on the replacement seatbelts, and as they are installed, I don't want to remove the trim again because of the 'gunky black sealant'
One advantage F.D.T.S. has, is that Autoliv/Safelex are based nearby, so the units are readily available to them.
It really is an easy job to change the belts, and the difference is very noticable.
Steve
Ghost
Postby Specky » Mon 09.04.2007, 17:39
Cheers for the Write up :-D
Can I be Cheeky and quote you in my earlier seat belt thread...HERE
Or extrapolate some of the information
Good skills
Postby Ghost » Tue 10.04.2007, 15:54
Dave,
If it is of any help, you can cut; carve; exerraippoooo - (muck about) with my thread as much as you like, as long as it does not cost me any MONEY!!!!
Steve
Ghost
Postby Specky » Tue 10.04.2007, 16:54
Ghost wrote:Dave,
Steve
Cool.. :-D
Seat Belts
Postby Steve A » Thu 10.01.2008, 19:22
:D I've just received my new belts back from F.D.T.S,what an excellent service considering that I only posted them last thing Monday.
I know it might seem to most people to be a boring thing to put right but it should be the first thing on the renovation list :!:
Postby GeoffSmith » Thu 10.01.2008, 19:51
Dave, did you ever get an Autoliv part no. from the retractor? :poke:
Postby Specky » Thu 10.01.2008, 20:32
geoffsmith wrote:Dave, did you ever get an Autoliv part no. from the retractor? :poke:
In a word no...
Gave up.. after finding the man that made them and FDTS.. :?
Postby Specky » Thu 10.01.2008, 22:14
In a word no...
Just thought Steve...
Was there a part No anywhere on the retractor...
Cos I've heard a rumour... part of the retractor is used on other cars...
and I've got a list of No's... :-D
Postby GeoffSmith » Thu 10.01.2008, 22:19
Specky wrote:
In a word no...
A bit slow tonight Dave! :smt019
Postby Steve A » Sun 13.01.2008, 20:37
:-D This is what was on my new retractors,
5113 15601 B
90-90 5096
Autoliv Aust.
I hope this is of some use :wink:
Postby Specky » Sun 13.01.2008, 20:50
Oh it is...
Thank you
Postby GeoffSmith » Mon 14.01.2008, 00:37
Specky wrote:Oh it is...
Thank you
So we won't be needing Colossus. :twisted:
Postby Rice crispy » Tue 22.09.2009, 16:50
guys just been reading the manual and it says you need to remove the sill plate to get the B post cover off ?? is this correct as I need to replace my belts and don't want to remove anything unnecessary :-)
Rice crispy
Return to Interior
