Doug wrote:FWIW, there's 3 temp sensors on the engine
one goes to the dash gauge ONLY
one goes to the ECU only (CTS)
and the other is for the coolant fans ONLY
they're all right next to each other at the thermostat
see this image
in the thermostat write-up for more info
WayneP wrote:Looks like I need one also. Pump runs when cold (with direct 12V feed), but doesn't when hot. I'll try taking it apart but I'm not hopeful!
The Bosch part looks identical, and a good price for the new part (especially for you guys in the UK at 2 dollars to the pound). Don't forget to post the actual result of fitting it.
WayneP wrote:Pump runs when cold but not when hot (both with direct 12V feed). Therefore I am assuming something is locking-up when hot.
There is power at the connector when it should be there; hot engine (hot enough for fans to run), then ignition off.
above is correct
