Doug wrote:Doc Fizzix wrote:when I discussed this same issue with Robie he was telling me that he would crack them loose and then re-torque, I do not have the balls to do that
I am no engine guru, but that has got to be wrong. There's no way it could get tighter on its own--only looser. Thus you only need to check the torque wrench on it to be sure it's tight. And the reason why is how the bolts are designed to stretch just a tad, and usually only supposed to stretch ONCE and if you retorque them they can break. Just blabbering anyway . . . .
Doc Fizzix wrote:Monty
If you have the bolts out, can you tell if they stretched? I have a couple new ones around that I can measure, try to measure the length of one of yours and we will compare. I am thinking maybe your bolts have stretched
CYLINDER HEAD BOLT A100E6189S EACH 5.04
chris.t wrote:Thats in a shocking state monty its gone all over the place
Monty wrote:Micheal,
Not 100% sure, but think it's more down to not re-checking the headbolts after use (even thou i went by the manual) and maybe the gasket u supply compress more than the lotus/isuzu type![]()
Yourself and DaPinky have fitted this gasket and had no problems, i did 250 miles and it was fine until the trackday
