lotuska wrote:
Should have really engaged brain...26lbf.in NOT 26lbf.ft, wish they'd stick to one standard in the manual.?
lotuska wrote:Also I don't have the spring on the cam belt tensioner, is this normal?
lotuska wrote:......... after the initial start up and run I checked the head bolts and they did need to be re-torqued
paulwatkins wrote:just thinking out loud...
lotuska wrote:On the head bolt issue, I’ll treat it like any other car that I’ve done head work on, and will re-check the head bolts after 500 miles.
lotuska wrote:How do you know that you are tdc? (obvious answer is from the markings on the crankshaft pulley) My concern is that I might have set the car up 180 degrees out.
lotuska wrote:Now the questions:
Ok I worked out that it doesn't really matter on the crank its the cam timing that's important. So I made sure that when at tdc that both the timing marks aligned on the cam shaft pulleys.
lotuska wrote:I decided to ignore the fact that you could turn the engine over one revolution more so that the crank pully again pointed to tdc but this time both cam shaft markings did not align.
