paulrwebster wrote:If any one else has any similar tales of heroic failure that they would like to confess to, please do post.
Monty wrote:Don't know if it was Brian, but someone did explain about bleeding the Wilwoods and u are only suppose to bleed from the bottom nipplesThe only reason why they have 4 nipples is so the caliper can be turn round and used on the other side.
But saying that it does make sense that the air would travel to the top and u would think bleeding from the top would be the way to go![]()
Hopefully someone will explain why
Monty wrote:Don't know if it was Brian, but someone did explain about bleeding the Wilwoods and u are only suppose to bleed from the bottom nipples![]()
F1 LOTUS wrote:Monty wrote:Don't know if it was Brian, but someone did explain about bleeding the Wilwoods and u are only suppose to bleed from the bottom nipples![]()
Pull the udder one Monty, it weren't me![]()
This would only be true in Australia![]()
Monty wrote:Well someone did as i was the 1st to have your kit fitted in the UK and i wouldn't of had a clue which bloody nipple to twist
chris.t wrote:regrettably russ you'll probably be smelling hot oil for sometime to come - i know
Turn to look at bench where two beautiful, brand new, still in the box torque wrenches I got for Christmas (which I specifically asked for by the way) are resting......totally undisturbed.
