need a new seal but dont know what i want
Postby router » Fri 01.06.2007, 11:46
Hello everyone,
Ive just bought an elan after 10 years of looking at them....
I need a new seal which resides between the roof and the top of the passenger side window.
Ive done some digging about and think I need an LHS intermediate seal can someone please clarify this.
router
Postby Gazza » Fri 01.06.2007, 13:57
If it's the piece in the photo, then I think you need the header seal(think that's what it is called). It runs above the windscreen and down both sides.
The intermediate seal is the small 7 inch one in the middle off the side windows.
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby router » Fri 01.06.2007, 15:35
This is the seal part I require, the existing is damaged.
Where can I get this and whats the cost
router
Postby Gazza » Fri 01.06.2007, 16:57
You need the Hood Header seal A100B6165S or the later B100B6165S if it's a late SE or S2.
The seal does not stop at the corner, it goes right around the front of the hood and along the other side.
Think they are still available from Lotus but are in the region of £250 or more.
Try trim-tech for a complete set of seals at about £300 (sure the header seal is include)
Gazza
SOLD
Gazza
Postby Monty » Fri 01.06.2007, 17:15
I got one from SJ`s a couple of years back for £145
www.sjsportscars.co.uk/partsandaccessories/parts.asp
Postby Gazza » Fri 01.06.2007, 17:30
They have both listed, but with different part numbers.
The early one is £182 + vat and p/p
SOLD
Gazza
Postby router » Fri 01.06.2007, 18:13
mines a 91 on a J plate
router
Postby Gazza » Fri 01.06.2007, 19:25
Before VIN # M 8161 it's the old style, after this VIN # it's the later.
That's of course your roof hasn't been changed already.
Gazza
SOLD
Gazza
Postby theelanman » Sat 02.06.2007, 11:34
how does you drip channel look on your roof???...
its the only way to tell......
the se original the drip channel as it came down the rear falling pillar (thats the back edge of the side windows...vertically).....was straight where as the s2 curved where it landed on the rear deck.....
clear as mud.....
I'll try to find some pics....
Postby theelanman » Sat 02.06.2007, 11:35
found some
Postby router » Tue 05.06.2007, 07:54
looks like I got the older roof seal, thanks for that.
router
Postby TrueBlue » Fri 20.07.2007, 12:28
Monty wrote:I got one from SJ's a couple of years back for £145
thanks for that monty
a few people have been saying in other threads that the seals cant be bought anymore? so this link is invaluable
I need the passenger side seal that runs down the rear(b post? by seatbelt?) edge of the window and also the 7 inch bit
is this LEFT HAND SIDE intermediate or? complicated isnt it
i might do a diagram for everyone once ive got this sorted
please can someone tell me which part numbers or names these bits of seal have...many thanks
TrueBlue
Postby ailwyn » Fri 20.07.2007, 12:43
Passenger side on RHD car is the Left Hand Side.
Drivers Side on RHD car is the Right Hand Side.
Seal coming down the hood at the rear of the window/b-post is the Fall/Falling Pillar Seal.
The short seal running along the top of the door glass is the Intermediate seal.
Header Rail seal runs along the top of the windscreen.
Rear deck seal runs under the plastic rear window.
A-post seals run down the front of the door glass/side of the windscreen.
A.
ailwyn
Postby paulwatkins » Fri 20.07.2007, 13:58
TrueBlue wrote:i might do a diagram for everyone once ive got this sorted
Thought I'd save you the trouble and simply copy some pages from the PARTS MANUAL. :-D
paulwatkins
