Replacement Windscreen
Postby Nemesis » Wed 20.06.2007, 08:01
I had the misfortune to hit a stone at high speed which cracked my original windscreen. It was replaced with a Rioglass "Star Glass" green tint screen which cracked the day I drove it home. A crack propagated from the driver's side edge & travelled about 2 inches. The crack was halted by drilling a hole at the point of the crack & impregnating with resin. Now,5 years later another crack has appeared in the same side,similar to the first. I intend halting the crack as before. My question is,does replacement with another "Star Glass"
screen make sense ? Do other members have experience with these,supplied by Lotus as replacement screens ? I assume the front drive configuration of the car is causing excessive movement in the A pillar & bulkhead which is twisting the screen,causing cracks. Do any members have a good fix for this problem.
It costs me heaps to do these replacements so I'm not keen on doing any more.
Any help much appreciated.
Nemesis
Return to Doors and Windows
