how to take the door skin off so i can change the speakers?
Postby myles » Thu 14.06.2007, 19:37
Can anyone advise how to remove the plastic door panels from the doors, so that I can change my door mounted speakers.
The drivers side window has started to play up too, so I now need to take a look at that too.
I have removed the screws holdoing the door panel inplace but have not been able to remove the panel which appeared to be glued in place.
Any help would be appreciated.
myles
Postby RayD » Thu 14.06.2007, 20:31
Myles,
It shouldn’t be glued in place, it just needs all the screws and the plastic screw plugs removing – I found one extra to the ones shown in the manual, in the middle of the panel.
RayD
Postby Gary » Thu 14.06.2007, 20:51
The door carpet is glued - you will need to remove that to get at the screws, but it should gently peel away
Postby M100 TWO » Thu 14.06.2007, 22:46
Myles go to www.charliex.net/door.htm. a smashing write up you cant go amiss with it I have put in new front speakers they don't have so much base as the old paper ones but are much clearer top end and I use the rears for the base I want
M100 TWO
door panel removal
Postby myles » Sun 01.07.2007, 13:32
MANY THANKS
for the picture highlightinga all the screw locations.
I feel much better about tackling this job now,.
One final question is, which glue did you use to put the trim back in place?
Thanks Again
myles
Postby RayD » Sun 01.07.2007, 18:56
The original glue may still be OK, but if not you need the one in a spray can that carpet fitters use. Just put it on the carpet otherwise it won't come off so easy next time. The one I used is M-Phatic Heavy Duty Spray Adhesive.
Ray
RayD
Postby TheBard » Sun 01.07.2007, 20:10
Hi Myles,
As for the window, check out the "Doors and Windows" section, and to get you started here are two long threads attacking the window mechanism issues...
My own initial adventure with windows.
Ekapol's superb adventures in repairing the allegedly unrepairable!
If you get stuck post a question, we're a helpful bunch ;)
Good luck,
Ian
TheBard
How to take the door skin off
Postby algirdas » Sun 01.07.2007, 20:46
Dear Myles:
I just had my door apart and put the door carpets back on with very benign rubber cement (Elmer's brand rubber cement that you just pour onto the carpet, spread it around with the enclosed brush and press it into place). Holds from the first installation and comes off very easily when you have to get back into the door to fix windows etc. (trust me, you will be seeing your door's innards again and again and again).
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Return to Doors and Windows
