Dico to lend a pair of TCA's to Gareth for his fabricator to copy in SS.
dapinky wrote:I've spoken with Chris Wittor, and I'm going to drop my wishbone off to him on Friday evening for him to see what bushes we need. If it's a 'stock' item, no problem, if they have to be fabricated, he will need a minimum order - watch this space........
He can match to shore rating of the poly bushes to the original material, so the Lotus designed handling shouldn't be affected - that said, he may offer alternatives if people want them - after all, Lotus were sticking to rubber, Polyurothane (spelt wrong ?:roll: ) wasn't about so much 20 years ago!
theelanman wrote:jimbob
where have you used your spare bushes??....
Ive only got space for 4bushes on each wishbone.....x2 wishbones = 8 bushes
youve listed 12 bushes???
just trying to clarify
cheers
gareth
theelanman wrote: wil send you a PM tonight after Ive spoken with the fab man
dapinky wrote:Gareth,
When i went to him back in the summer(?) he gave me those ones as free samples, so any extras will need to be purchased.
This probably isn't a big problem, as long as we're happy with the sizes/shore ratings as per the samples.
Anything else will need to be a 'special order' and subject to a minimum of 100 units.
I'm not in a possition to visit him personally this week (as it's about 50 miles round trip into the wilds of Somerset) but he is availlable on the interweb at www.superflex.co.uk (online ordering is possible) and lists his phone number if your fabricator wants to talk directly with him.
Not (necessarily) trying to pass the buck, just minimise on any confusion which may arrise from 'lost in the translation' phone calls and then with the current uncertainty of Royal Mail, any postal problems via myself/yourself etc. and the rapidly approaching date of 4th November!
The units originally supplied were:-
SPF0706 6192705 Track Control Arm Inner Bush; Two Top Hats & One Stainless Steel tube (Uses 12mm bolt) Cosworth, 4x4 & Early 1990's 2L Ghia - £11.10 inner bush)
can't find the part number, but it was a Rootes Sunbeam part, for the outer bush (I will look when i get home later - work computer won't let me search for that page)
dapinky wrote:The cosworth bushes as provided were a few mil too long (2 part bush) and need to be shortened (also the stainless centre tube)
the 2-part bushes are 45mm tube, and 12mm bore
