ratman wrote:The shifter is fitted (I bought it in November!) and it is all like it had to be. Really much more precise and solid shift with shorter throw. My only problem is that the fith gear is hard to engage. Dave as I have the standard cables, what have I to see to improve the engaging?
Dave wrote:
Hard to say without more info. I'm assuming it was OK before so sounds like some cable adjustment is req'd - do you have the service manual which tells you how to do this?
Can you select reverse OK or is it the same as 5th? If the same as 5th then the cross gate cable probably needs adjusting Best way is to put the box in 5th by hand, loosen the cable adjuster
ratman wrote:... is not really easy to loose the cable adjuster! how do you make it??
John_W wrote:ratman wrote:... is not really easy to loose the cable adjuster! how do you make it??
Spray the plastic serrated twist-locks behind the engine with plenty of WD40 and leave it for a day, then just keep working at it. They only move half a turn.
abmunro wrote:Hello Dave
Do you do a fitting service?
Dave wrote:abmunro wrote:Hello Dave
I'm always open to negotiation , I would even consider travel to California
if the expenses were covered
Warning: getting south of the river constitutes International travel for me![]()
A lot depends on how / where / if you buy it
Doug wrote:Dave, you'd better update your profile with where you're based so we know what airport to get the tickets for
A lot depends on how / where / if you buy it Laughing
or three if you can get the car to me.
Dave wrote:A lot depends on how / where / if you buy it Laughing
By this I meant if you buy them here I might be willing to do the install FOC or maybe aor three if you can get the car to me.
lotusesprit wrote:Dave,
I sent you a PM about my interest in the short shift kit. I live in San Diego, CA and would like to know how to obtain this kit.
Thanks,
Eddie
Thanks,
Eddie
tigerdog wrote:Maybe Dave's in Miami, too? Or Majorca?
geoffsmith wrote:Sunny Whitley Bay actually.
abmunro wrote:Your problem is, same as anybody else making stuff for the Elan, There is only a very small market. ie only 4000 made
Could you give me a list of other parts I should purchase to make the gearchange as sweet as possible.
Come on guys, what are you waiting for Users browsing this forum: No registered users and 4 guests
