central blocking
central blocking
Postby DaveT » Sat 15.09.2007, 07:12
8)
My central locking does not appear to be working correctly.
Firstly I do not have a remote- just a key.
The key only operates the door it is used on but you can hear the c/l trying to do something.
If you are in the car and depress the passenger door lock button, both doors will lock. If you depress the drivers door button the passenger door will not lock but again it makes noises as if it is trying to do so.
Any simple ideas as all the connections seem to be OK.
DaveT
Re: central blocking
Postby rip » Sat 15.09.2007, 16:26
DaveT wrote:Firstly I do not have a remote- just a key.
I do not have a key- just a remote ;-)
DaveT wrote:The key only operates the door it is used on but you can hear the c/l trying to do something.
Listen to a couple of other Elans at Bishops Stortford tomorrow. We may hear something that is relevant.
Postby Elanlover » Tue 18.09.2007, 18:54
rip wrote:I do not have a key- just a remote ;-)
You two guys need to get together :wink:
Postby GeoffSmith » Tue 18.09.2007, 20:53
Dave, meet Iain. Iain, meet Dave. :-D
Postby Joe » Fri 12.10.2007, 22:17
We have a remarkably similar problem I've just started a new thread stating the same problem before reading this.It is a real pain in the Butt if you have solved the problem please tell me how
Joe
Postby Dave Eds » Fri 12.10.2007, 22:42
Joe wrote:It is a real pain in the Butt
are you doing it correctly? :shock:
Postby Joe » Fri 12.10.2007, 22:58
I knew she was upset about something but I could not figure out what. :D
Joe
Return to Doors and Windows
