Sorry, I know this one has been round a few times..... but....
I'm looking to get some Redline Gearbox oil to see if it will improve my shifting, as others have found.
What I can't figure out is which one to get for. I asked redline and got told:
just check what grade and viscosity is recommended for your
particular car- if it needs an 80 weight you need Red Line MTL- if it needs a 90 weight you need MT90 which is the heavier grade of the same product.
From reading around I think most people are using the MTL product but a there seem to be alot of references to 90 weight.
Reading through the descriptions on Redlines productpage I'd lean towards the 90 weight as being the correct one
Anyone advise on their opinion of which is likely to make more difference to a dodgy shift?
Thanks,
Dan
