by kenninuk » Tue 13.11.2007, 19:49
Having just removed my rear bumper (1992 SE) I found that one of the four main screw threads had come away from the inside of the bumper i.e. it was mounted in the fiberglass and is no longer
Has anyone had a similar problem? Does anyone have recommendations on the best way to re-fiberglass in new mounting bolts?
Many thanks
Kenn
kenninuk
by Dico » Wed 14.11.2007, 11:51
PaulP has had the same problem..... But hasn't fixed it.
Probably fibreglassing it back into place is your best option
edit- ah, that was your question
answer- lots of it!
- Fool Boy Four - Founder
by mikeydude » Wed 14.11.2007, 16:07
It's impoertant that there is NO grease or dirt whatsoever, plus the original fibreglass needs to be "keyed" by scoring and sanding it to make it rough. Mix the resin exactly as described and DO NOT move or mess with it as it is curing and make sure you don't do it outside at this time of year.
Use a stubby brush to pad the resin and rub it against the original fibreglass to make sure its bonded properly. most sure the glass matting goes in different directions to get the best strength
mikeydude
by Paul.P » Wed 14.11.2007, 18:51
Dico wrote:PaulP has had the same problem..... But hasn't fixed it.
Really
, i havn't took rear bumper off & knackered the fibreglass !
Oh, you mean the 2nd hand one i bought, silly me, still
by Dico » Wed 14.11.2007, 19:14
Heres the question-
So you do have the same problem flipper? Or is my imagination running wild?
by Paul.P » Wed 14.11.2007, 19:16
Youv'e gotta read the post as a whole, & not disect it Silver, god, its hard work sometimes
by Dico » Wed 14.11.2007, 19:25
So the only difference between what you did and what Kenn did is the actual removal of the bumper????
The actual problem is exactly the same.
kenninuk wrote:one of the four main screw threads had come away from the inside of the bumper i.e. it was mounted in the fiberglass and is no longer
So Flipper, as far as I am aware you have repaired said bumper. I was merely suggesting you may be able to help.
But as you haven't answered Kenns question I can only assume you are deliberately being unhelpful or, you haven't carried out a repair?
You know Parsnips, you're one BIG
LEMON when you want to be!
Stands back in anticipation as the biggest wind up of the night unfolds
by Paul.P » Wed 14.11.2007, 19:53
Dico wrote:So the only difference between what you did and what Kenn did is the actual removal of the bumper????
Kenn, i do have a bumper with the same problem as yours. I bought it 2nd hand, & as yet have not repaired it.
If i remember when my car was hit up the rear, they had a similar problem, & repaired it with some stuff that came out of a tube, think it was called Rhino Bond ?, but i don't know if its a trade only stuff or not.
by Dico » Wed 14.11.2007, 20:05
Not too difficult eh Clownfeet
by Paul.P » Wed 14.11.2007, 20:10
Dico wrote:Not too difficult eh Clownfeet
Where's the welsh MOD when you need him ?, talk about crap on the EM thread
by kenninuk » Wed 14.11.2007, 20:22
Guys Guys Guys. I hadn't realised that a duff mounting bolt was so controversial
Thanks anyway for the entertainment and advice (mikeydude). I've got the fiberglass, resin, brush and self amalgamating tape (more about that later) and will set to work over the next few days. I'll take pics and if successful will share them.
Bye for now.
Kenn
kenninuk
by Dico » Wed 14.11.2007, 20:25
kenninuk wrote: will share
Nice one Ken, thats what its all about.
Mackerel breath Parsnips got there in the end.
by Paul.P » Wed 14.11.2007, 20:27
Kenn, me & Dico love each other really
Hope you get it sorted !
by Dico » Wed 14.11.2007, 20:29
I'd sooner snog Murphy though
by GeoffSmith » Wed 14.11.2007, 20:55
Is the 14th November a Welsh bank holiday or something?
- Kitty Fiddler
by Paul.P » Wed 14.11.2007, 21:02
geoffsmith wrote:Is the 14th November a Welsh bank holiday or something?
Tell you Geoffers, mods are like coppers, never one when you need one
Apologies to Dapinky.
by Monty » Wed 14.11.2007, 21:13
Dico wrote:I'd sooner snog Murphy though
F**k not again
Mr.P you`ll have to get a face lift so i can pass silver on to you
BTW will sikaflex not do the job?
(Paul I don`t mean for your face lift
- Chunder King!
by Paul.P » Wed 14.11.2007, 21:16
Monty wrote:BTW will sikaflex not do the job?
(Paul I don't mean for your face lift
Use Botox myself Monty, & that ain't working either
by mikeydude » Wed 14.11.2007, 21:58
Yo,Dicky boy...keep your hands of my bitch.. monty's mine....
mikeydude
by surfboardfiller » Thu 15.11.2007, 19:47
Kenn if you re laminate the GRP you can soften the existing surface with a little acetone to get a better bond. You can fill any voids with resin mixed with a load of fibres cut from some glass cloth.
surfboardfiller
