by surfboardfiller » Mon 10.12.2007, 18:26
I am trying to remove the front bumper but it's not coming off.
I un bolted:
The Undertray 4 bolts
Height adjusters behind the wheel arch
4 Main bolts in and under the light pod compartments
but I think there may be more? The service manual says M6 nuts to the radiator but I can't find them. Please help!
Yes can't find my nuts!
before you lot start!
surfboardfiller
by muley » Mon 10.12.2007, 18:36
I think there were some other nuts and bolts holding the lower 'wing' pieces at either end in place. Also, at each end there are some bolts going into a j clip in the bumper (step 2 on page 19 - second sentence). There are no nuts and bolts going to/from the rad or rad support.
Can't think of any others ... Have you got the liners out? If they're off more might be revealed.
by Paul.P » Mon 10.12.2007, 19:12
Phil, i'm pretty sure on SBK's bumper, there was some bolts behind the indicators !
by surfboardfiller » Mon 10.12.2007, 19:32
Thanks Muley, I got the ones next to the undertray. Sheared to pieces.
I'll take out the lights tomorrow and find the other 2. Thanks Paul!
surfboardfiller
by DeeAitch » Mon 10.12.2007, 20:57
Think I've seen a couple lurking under the main light pods when I was looking at the main beam wiring
DeeAitch
by muley » Tue 11.12.2007, 10:08
Paul, Phil,
When I removed the bumper I left the lights in and installed the lights before refitting...
I did confuse myself initally by removing 2 clamshell bolts instead of the 2 bumper nuts from under the headlamp pods ...
by surfboardfiller » Wed 12.12.2007, 22:37
I found them! 2 on each side just inside the wheel arch! Got the Clam off too!
Cheers all!
surfboardfiller
