Tyre Pressure?
Tyre Pressure?
Postby Galsia » Sun 20.01.2008, 12:38
Galsia
Postby theelanman » Sun 20.01.2008, 12:49
IIRC general thinking is somwhere between 26 and 31...
just depends on your tyres, the current state of wear and how you like the car to ride :?:
Postby theelanman » Sun 20.01.2008, 12:55
Postby Galsia » Sun 20.01.2008, 16:59
Galsia
Re: Tyre Pressure?
Postby Rambo » Sun 20.01.2008, 22:11
Galsia wrote:Looking at my Elan last night I noticed that the tyres could do with some more air in them. Does anybody know how much PSI I should get them to? There is nothing mentioned in the manal.
Thanks.
Check in the back of your owners handbook - I'm sure 28.5 psi was the recommended tyre pressure with the original Michelin tyres ? IIRC there was a slightly different psi for N/A's ???
Postby GeoffSmith » Sun 20.01.2008, 22:30
My S2 handbook says 29 psi all round for Pilots.
Postby Dave Eds » Sun 20.01.2008, 22:55
SE 26.5 all round NA 32 all round page 60 of handbook
Postby paulwatkins » Sun 20.01.2008, 23:09
Service bulletin 1996/01.
For the pressure values shown in the bulletin,
1.8bar = 26psi
2.0bar = 29psi
2.3bar = 33psi
(roughly)
paulwatkins
Postby GeoffSmith » Sun 20.01.2008, 23:31
2 Bar = 29 psi :-D
Postby Specky » Sun 20.01.2008, 23:35
geoffsmith wrote:1 Bar = Pis-ed :-D
1 bar = 14.7 psi (atmospheric pressure @ sea level)
Postby GeoffSmith » Sun 20.01.2008, 23:56
1 atm = 14.696 psi
1 bar = 14.504psi
Postby paulwatkins » Mon 21.01.2008, 09:29
And now wiki'd
HERE
paulwatkins
Postby Rambo » Mon 21.01.2008, 13:15
I've always taken 1bar to be 14.55 psi
Postby GeoffSmith » Mon 21.01.2008, 14:04
14.50377 if you want to be picky.
Wonderful Wikiing Watkins! :-D
Postby Monty » Mon 21.01.2008, 18:27
geoffsmith wrote:14.50377 if you want to be picky.
Just like my boost gauge :wink:
Re: Tyre Pressure?
Postby surfboardfiller » Sun 03.02.2008, 16:23
Thanks.
Just for the record,
It's in Technical data at the back of the manual and referrers only to the tyres the car was fitted with originally. My Yokohamas are 35-44 psi (its written on the side of the tyre). ~10 psi more than the MXX-2 tyres recommended in 1991!
Cheers me dears.
surfboardfiller
Postby GeoffSmith » Sun 03.02.2008, 16:56
I've only ever seen maximum pressures marked on sidewalls (my Pilots are 50PSI max). Is this a new innovation?
PS What's that custard avatar young Phil? :-D
Postby surfboardfiller » Sun 03.02.2008, 17:11
geoffsmith wrote:I've only ever seen maximum pressures marked on sidewalls (my Pilots are 50PSI max). Is this a new innovation?
Yes, max psi is marked at 44. I usually put in 38 the other figures were advised at the time of purchse.
Its my new toy! :-D I followed the good advise of WillB :-D Its really good to drive, so much fun, even just about town! It gets lot's of attention too so I feel safer than in the BRG Elan or the blue Mitsubishi. :wink: The track Elan will be Custard too! :-D
surfboardfiller
Re: Tyre Pressure?
Postby Monty » Sun 03.02.2008, 21:05
Cheers me dears.
IMHO 35psi+ is way to high, i don`t even put that in the van :?
When doing a trackday i`ve been down to 19psi cause i can get 8 to 10 psi increase as the tyres warm up
Postby surfboardfiller » Sun 03.02.2008, 21:23
Are you on low profiles with 16" wheels? I have 15" wheels and it's just road use for this car, mostly motorway, 28 psi drags a bit; the tyres are softies. :?
surfboardfiller
Return to Wheels and Tyres
