nitroman wrote:Blair, what was the freight fee? It only says the reichmaster will post to Deutschland, and my German isn't good enough to converse with Herr Cromenführer.
Elanlover wrote:Thanks Dave. To me, it looks like there's only one real difference to be concerned about. The left side panel, 3rd icon from the right says the word "BRAKE" in the fed model but the UK OEM panel has the icon of the old drum brake with the exclamation mark inside it.
Would anyone in the UK have an issue with using the word "BRAKE" instead of that icon? If I don't hear back from anyone I'll tell them to use the same panels for Fed and UK cars.
Elanlover wrote:Can't wait to see them installed Nige. I'm on vacation right now and won't see mine for a few weeks when I return. Interested to know how you plan on replacing the faces and doing the requisite "needle work".
.tweetdriver63 wrote:What's that at spot 13 on the European version where the US is a blank?
geoffsmith wrote:tweetdriver63 wrote:What's that at spot 13 on the European version where the US is a blank?
Cat overhead - Japan only.
Nige wrote: I had it all back together yesterday only to discover that the Tacho was over reading by something like 1000-1500 RPM, despite having carefully marked the needle positions before I removed themso I had to take it all apart again today.
Nige wrote: I had it all back together yesterday only to discover that the Tacho was over reading by something like 1000-1500 RPM, despite having carefully marked the needle positions before I removed themso I had to take it all apart again today. The same goes for the boost gauge which is still to do.
Nige wrote:I have a few other things still to sort. I changed the filament bulb in the voltmeter for a LED and now have no dial illumination anywhere, despite having changed back to a bulb, no obvious loose wires or blown fuses. Some of the tell tales have stopped working as well, most noticably the handbrake warning light, I need to get back behind the panel and recheck all the twist fit lamps.
Nige wrote: I needed to drill out the holes for the needle stops a little as my first attempt to refit a needle stop resulted in it breaking because the hole was too small, fortunately I had a spare. Also the alignment of the holes with the mounting clips on the instruments themselves was almost perfect, but not quite, again plastic dial faces would probably have fitted but the rigid nature of the steel meant that I had to take a small file and a scalpel to the plastic of the instruments to trim a 1/2 mm here and there.
tweetdriver63 wrote:geoffsmith wrote:tweetdriver63 wrote:What's that at spot 13 on the European version where the US is a blank?
HA! I assume you meant overheat.
