gears
Drivetrain problems
gears
Postby markmeace » Sun 16.03.2008, 22:40
hi gazza could you advise me please i drove lotus home m951ojb and developed a problem changing gears had a lot of trouble engaging them the guy i bought the car of said it could be the hydraulic clutch needs bleeding or something is this right or is it something more serius he said to get it sorted and he will pay for it would appreciate any advice asap as im quite worried about this thanks mark.
markmeace
Postby Sy V » Sun 16.03.2008, 22:51
They haven't got hydraulic clutches.
LEC Godfather
Postby markmeace » Sun 16.03.2008, 22:54
didnt know it doesnt have hydraulic clutch any ideas wot it mite b
markmeace
Postby paulwatkins » Sun 16.03.2008, 22:57
It could be that the clutch cable needs some adjustment or the gear selector cables need adjustment.
paulwatkins
Postby markmeace » Sun 16.03.2008, 23:23
Could anybody recommend anywhere in manchester where i could get this problem sorted quickly.
markmeace
Postby Specky » Sun 16.03.2008, 23:35
Monty...
Dico...
Postby theelanman » Sun 16.03.2008, 23:50
markmeace wrote:Could anybody recommend anywhere in manchester where i could get this problem sorted quickly.
you can try esprit cars (he specializes in lotus....as he used to work for chris neils).....
kevin (esprit cars)
01614560800
he's in hazel grove right next to the railwaay station....
cheers
Gareth
Postby inkitin » Mon 17.03.2008, 00:42
kevin (esprit cars)
01614560800
cheers
Gareth
Yes. I've just started using Kevin for looking after my Elan and would recommend him as well.
91 SE Calypso Red
inkitin
Postby Ghost » Mon 17.03.2008, 20:58
Check the gear change cables on the bracket attached to the rear of the engine to see if both plastic locking connections are intact.
When I first bought my Elan, the gear change was VERY poor, but I put that down to wear in cables/selectors etc.
In fact, the fore/aft selector cable was secured to the bracket with zip ties as the locking nut had sheared off.
Replaced both cables with AB's and fitted Dave's short shift kit.
This was the best modification I have come across for the Elan, as the difference in gear changing is remarkable!
Spending the kids inheritance
Ghost
Users browsing this forum: Bing [Bot] and 4 guests
