Postby Galsia » Mon 17.03.2008, 12:52
Galsia
Postby Enright » Mon 17.03.2008, 13:20
With or without runners? (It's still a LOT - mind your back!)
But I have a couple without at home that I could stick on the scales.
Postby Galsia » Mon 17.03.2008, 13:43
Galsia
Postby Sy V » Mon 17.03.2008, 13:44
Well I reckon you're miles out.
LEC Godfather
Re: Seat Weight
Postby inkitin » Mon 17.03.2008, 13:58
Galsia wrote:Does anybody know how much the standard seats weigh? I need the weight for a courier.
Thanks.
38 lbs each (17+ Kgms) according to the "seat Warmer" upgrade write-up. Having recently taken one out I can believe it as well !!
91 SE Calypso Red
inkitin
Postby WillB » Mon 17.03.2008, 17:48
Galsia wrote:With runners. I reckon about 7kg per seat at a guess.
:shock:
They are VERY heavy, 17kg each as quoted above sounds right.
WillB
Postby Monty » Mon 17.03.2008, 19:22
I weighted them at when fitting bucket seats
Stock seat with runners 38lb (17.23kg)
Postby chris.t » Mon 17.03.2008, 19:56
Monty wrote:I weighted them at when fitting bucket seats
how much did your buckets weigh Monty?
Postby Monty » Mon 17.03.2008, 22:05
The weight of a bucket :-D
Cobra seat with adapted runners 35lb (15.87kg)
The adapted runners weighed in at 14lb (6.35kg)
That makes the Cobra seat 21lb (9.52kg)
Postby bratboy_y2k » Fri 04.07.2008, 18:45
does anybody have pics of the insides of a seat? id like to see if any of it can be replaced with lighter components. yes it sounds crazy but i actually like the look of the original seats. i dont mind finding a thrashed seat and seeing if bits can be replaced with aluminium and cf.
bratboy_y2k
Postby Don.Hasi » Mon 07.07.2008, 21:32
WillB wrote:They are VERY heavy, 17kg each as quoted above sounds right.
:shock: :shock: :shock: Are the seats part of the passive safety concept in case of laying on the back? Or is there any other reason for it?
This is really much... the seats of the elise/vx weigh 10kg sth. incl the runners... so if there is a rollbar needed regarding the protection concept, the bar must weigh less than 14kg... ;) but of course... the seats belong to the first sight/appearance of the car... it isn´t easy to substitute them without changing the shape of the Elan
Don.Hasi
Postby Galsia » Mon 07.07.2008, 22:05
When lifting them, most of the weight was on the bottom bit of the seat if I recall correctly.
Galsia
Return to Interior
