Pinky II
Postby Rambo » Fri 04.05.2007, 08:05
Monty wrote:France this saturday will be a good test for Pinky :shock:
Bon voyages Monsieur Monty - hope you and the silver fox don't need that relay cover after all your head gasket work. Which circuits are you going to ?
Postby Monty » Fri 04.05.2007, 10:34
Sunday is Folembray and Monday at Abbeville, actually the Folembray ones looks a little scary as i believe it set in a forest, so on certain parts of the circuit there are trees fairly close to the blackstuff :shock: I`ll be taking it easy on that one then :roll:
Postby Monty » Mon 02.07.2007, 10:44
Managed to get 2 spare S2 wheels which i`ve refurbed myself in Metallic Graphite Grey and they`ve come out quite well. 1 wheel had 2 small parts that needed filling on the rim, so used Araldite multi-purpose putty which sets in minutes and can be sanded, u can even drill and tap this stuff :shock: I manage to get 3 brand new KUMHO V70A ECSTA trackday tyres of ebay for a bargin price, Camskill also sell them www.camskill.co.uk/products.php?plid=m12b102s690p0
I will take these with me on my next dry trackday and put them on the front to see if i can get more grip at the front to combat understeer.
I can get one in the boot and one on the passanger seat :-D
Refurbed S2 wheel
S2 wheels with Kumho tyres
(49.52 KiB) Downloaded 57 times
Postby Monty » Sat 27.10.2007, 17:19
Well head is off for the 3rd time this year :twisted: On my last trackday at Aintree i started to get slight temp issues again and colud smell fumes in the coolant. When i did the last gasket i enlarged some of the water holes in the gasket to match the head and block, which was difficult to cut and though that must be the reason why it`s failed again :? well with the head removed it`s gone in a completely different place, the failure is at number 1 piston :roll:
Also checked my torque wrench against Dico`s new halfords one and mine seems to be out about 3Nm at a setting off 78Nm, but last time i set it to 80Nm so that should of been fine :?
So tomo`s a new gasket will be going back on but but this could happen again :twisted:
No2 head gasket failed at #1 piston ring
No2 head gasket failed at #1 piston ring.jpg (57.84 KiB) Viewed 8257 times
Postby Rambo » Tue 30.10.2007, 18:46
3 head gaskets in a year !! :banghead: :banghead: :banghead: What's going on ?? Sounds serious ?? Are you skimming the head each time ??
Postby Monty » Tue 30.10.2007, 19:05
Rambo wrote:3 head gaskets in a year !! :banghead: :banghead: :banghead: What's going on ?? Sounds serious ?? Are you skimming the head each time ??
Tell me about it :cry:
Don`t know whats going on :?
Don`t remember seeing anything in the history file about the gasket ever being done, so 17 years isn`t bad.
So the 1st gasket I did was with Kmckmc`s gasket, which IMHO was a softer material and as i didn`t recheck the head bolts after 500miles they came lose :roll:
2nd time, i used the Lotus/Isuzu type and don`t understand why that failed (maybe a bit of Kak was in there) :?
So now i`m on the 3rd :shock:
Was speaking to a mechanic today and explain the situation, he said when rechecking the head bolts did i crack them open a 1/4 turn then reset them to the correct torque :shock: but i always believed that u do not loosen of the bolts :?
If thats the case, what i don`t understand is do u loosen them all by a 1/4 turn or one at a time? if one at a time what sequence do u use as you`ve got 2, 1 for undoing and what for tighting :roll:
Postby Doug » Tue 30.10.2007, 19:18
well I certainly wouldn't undo more than one at a time, though I'm not sure they really need to be backed off, but just torqued to be sure they are tight.
Postby Rambo » Tue 30.10.2007, 19:29
Monty - I'm certainly not an expert (awaiting comments from yer pal Dico !) and I don't have the manual at hand to check but torquing/re-torquing info should be in there? If not, check the right procedures with Christopher Neil/Paul Matty etc...
PS Did you skim the head last time ?
Postby DeeAitch » Tue 30.10.2007, 20:31
Monty, something not right here :(
I would check if the head and block are flat before sticking it all back together.
DeeAitch
Postby Paul.P » Tue 30.10.2007, 20:38
DeeAitch wrote:Monty, something not right here :(
You could have a good point there :? , but think its back together again :?:
Postby Specky » Tue 30.10.2007, 20:50
You're right Monty....
It's a TQ Check... If it fails... carry on torqueing to the correct amount. in sequence.....
if she fails and post re-torque, do another Tq check later, do this two to three times and she should settle...
Postby Rambo » Tue 30.10.2007, 21:22
Exactly my thoughts Dave
Postby Monty » Tue 30.10.2007, 22:02
Rambo wrote:Monty - I'm certainly not an expert (awaiting comments from yer pal Dico !) and I don't have the manual at hand to check but torquing/re-torquing info should be in there? If not, check the right procedures with Christopher Neil/Paul Matty etc...
Sorry, i did mean to answer that :roll: Yes head was skimmed last time
Nope there`s nothing in the manual for backing of on the recheck :? but if thats a normal procedure then it may not mention it :?
Think i may ask the guy who skimmed my head as he builds engines + i`ve got to nip to CN`s since i nicked pauls spare head gasket :lol:
I`m with u Doug, but i do remember Doc (?) mentioning about backing off before rechecking :?
But if u do need to crack them open one at a time which order do you use as you could warp the head :?
Postby Monty » Fri 28.03.2008, 12:38
BTTT
Postby Paul.P » Fri 28.03.2008, 13:40
You lost your stripes Murph ?
Postby Monty » Mon 31.03.2008, 16:54
As some of you will know Pinky looked slightly different at Donny as Pinky has gone Hard lol
The carbon fiber Hardtop was fitted just over a week ago down at SPC Design courtesy of Simon
The wheels were resprayed to Graphite grey and the cat design center caps were fitted. Also fitted the Silver Lockwood dails :-D
Edit, photo`s added for Gareth showing the bracket for the rear clamp on the hardtop (R/H side)
Pinky at Donny
sc_small [640x480].jpg (64.61 KiB) Viewed 8366 times
Hardtop Front
Hardtop rear
Resprayed wheels
Postby Gazza » Mon 31.03.2008, 17:12
Looking good Monty, any pictures of the dials.
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Doug » Mon 31.03.2008, 17:35
Nice one, Monty. :smt023
was hoping to get some pics/stories/feedback about lapping Donington from ya . . .
will check other threads for these answers though . . .
Postby Dico » Mon 31.03.2008, 19:54
Yes he got lapped a few times :-D
But as always, once the rain came the Elan came into its own and Pinky slaughtered the Elises ;-)
Postby Monty » Mon 31.03.2008, 22:09
Gazza, I`ll get a photo soon.
In bright day light conditions it`s difficult to tell that there silver, almost look white :roll: and you have to look carefully to tell that i`ve still got the white dial boost gauge.
Doug wrote:Nice one, Monty. :smt023
Doug,
I`ve got no video as i wasn`t allowed to use my suction mount on the camera :twisted: so i`ll have to invest in a clamp mount :roll:
Had a good day, no spins and kept it on the black stuff. Bought some Hankook trackday tyre for the front after the others were worn and they were squeeling like a pig (or should that be a Dico) and weren`t gripping like the Kumho`s that i had on before :roll:
The morning was dry and there were some very fast cars out there and some were race drivers from the Elise trophy so i just kept out of the way. Then the rain came in the afternoon in which i started to get past a few Elises :-D and the track became very quite as the RWD don`t like a bit off dampness :lol:
