Pinky II
Postby L.G. » Mon 31.03.2008, 23:28
It looks gorgeous Monty, wheels and hardtop make a very nice combination.
L.G.
'95 S2 driver #286
L.G.
Postby Monty » Thu 03.04.2008, 22:00
Cheers for the comments LG :smt023
A Pic for Gazza :-D
All i need now is a black & silver horn badge :?
Lockwood silver dails & Elise steering wheel
SE Steering wheel dismantle 008.JPG (152.25 KiB) Viewed 7341 times
Postby Nige » Fri 04.04.2008, 09:06
Thought you had a switcher chip? that looks like a Turbo Dynamics MBC sticking out of your dash?
Back in Blighty
Nige
Postby rip » Fri 04.04.2008, 09:22
Nige wrote:Thought you had a switcher chip?
Yep, look directly above the gearstick. Looks set to no.6, which it was when I was with Murph on Saturday.
Nige wrote:Sticking out of your dash?
I think that may be the manual fan switch.
I see what you mean about the silver/white difference being subtle in daylight. I didn't notice the boost gauge was a different colour, (& I did have my eye on what was going on while I was pax).
I was impressed with Pinky, especially as it was wet when Murph was driving me round.
Postby Nige » Fri 04.04.2008, 12:06
I can see the switcher, just curious about the big round blue and white (silver) thing, it's a big fan switch and that looks a bit like a turbo dynamics logo on it, hence the question.
Back in Blighty
Nige
Postby Dico » Fri 04.04.2008, 15:24
Nige wrote:looks like a Turbo Dynamics MBC sticking out of your dash?
As Honk Kong Fooey would say - 'Could be' :P
I want to know what Dale Wintons got to do with it :?
Postby Gazza » Fri 04.04.2008, 16:48
Cheers for the picture Monty.
Why the change from white dials, just better colour match with car?
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Monty » Fri 04.04.2008, 18:38
Nige wrote:I can see the switcher, just curious about the big round blue and white (silver) thing, it's a big fan switch and that looks a bit like a turbo dynamics logo on it, hence the question.
Yep it`s a MBC, but it`s turn off at the mo since having the HG problems. The Switcher is set to 6 which is just the V5 everest.
I have ran at 15psi which is just a tad over 1bar but at the moment don`t want to push my luck with the HG.
Postby Monty » Fri 04.04.2008, 18:44
Gazza wrote:Cheers for the picture Monty.
Gazza
I did want silver dials to start with but i couldn`t find a silver faced boost gauge with a black bezel, but after a year with the white ones i thought what the hell and decided i wasn`t to bothered about the boost gauge being white :-D Anyways the white ones are common :lol:
Postby Nige » Fri 04.04.2008, 19:24
Ta monty, couldn't work out why you had both, but there again I still have a FCD under the bonnet, disconnected but still there.
Back in Blighty
Nige
Postby Elanlover » Fri 04.04.2008, 19:54
Monty, Metal Monkey will make some beautiful silver dials for you :D
Postby Monty » Fri 04.04.2008, 21:18
Elanlover wrote:Monty, Metal Monkey will make some beautiful silver dials for you :D
Not for £30 they won`t :smt044 + i got £18 for my old ones so they only cost me £12 :wink:
Don`t want to be spending any more money on the dials as one day i`ll do something similar to LGM`s main dials. But it won`t be this year :roll:
Postby rip » Sat 05.04.2008, 10:26
Monty wrote:one day i'll do something similar to LGM's main dials. But it won't be this year
You have my attention there, Murph!
I think the Elan's rev counter is far too small, so would like to change my dials too......in time.
I also have a list to get through before that gets added, so maybe we'll be looking at this at the same time?
Postby RayD » Sun 06.04.2008, 10:09
Specky wrote:
It's a TQ Check... If it fails... carry on torqueing to the correct amount. in sequence.....
if she fails and post re-torque, do another Tq check later, do this two to three times and she should settle...
I’ve read the posts on the cylinder head bolts several times and I still can’t understand what this means :? – any chance of an explanation Dave?
Ray
RayD
Postby RayD » Tue 08.04.2008, 11:15
Monty wrote:
Was speaking to a mechanic today and explained the situation, he said when rechecking the head bolts did I crack them open a 1/4 turn then reset them to the correct torque :shock: but I always believed that u do not loosen of the bolts :?
Doug wrote: Well I certainly wouldn't undo more than one at a time, though I'm not sure they really need to be backed off, but just torqued to be sure they are tight.
Specky wrote:You're right Monty....
I hope I’m not repeating what Specky is saying…. :?
You are right, once torqued up they don’t want slackening off for any reason.
The mechanic was wrong.
Ray
RayD
Postby Monty » Tue 08.04.2008, 16:04
Don`t worry Ray, i didn`t take that mechanics advice as he was a scouser :lol:
Postby Dico » Wed 09.04.2008, 07:14
Wise man Murph. He'd have probably nicked your bolts if you had backed them off.
Postby Monty » Sat 26.07.2008, 17:57
Well it`s come to that time of the year again so in preperation for the MOT last weekend i fitted Bob Browns rear sliding pins (Doorman type) with new pads fitted to front & rear. Well Pinky went in for it`s MOT today and passed with no Problems.
Here`s the results of the brake test
.....................N/S.........O/S
Rear................90..........90
Handbrake......160........160
Front..............330........360
Balance..........200........200
Postby GeoffSmith » Sat 26.07.2008, 18:28
Monty wrote:Here's the results of the barke test
Woof woof? :-D
Postby Candles » Sat 26.07.2008, 21:38
Just MOTd mine and I have the smaller Wilwood kit on the front, with similar results to yours (kgf I presume?). My rears are MUCH lower though. I'm getting about 60-70 on the footbrake and not much more on the handbrake. This is with Dormans, greenstuff pads and drilled/grooved discs.
What am I doing wrong?
Candles
