Coolant that came out was green in colour which is more likely to mean a blue was used rather than a red, I assume
ailwyn wrote:When I asked at my local motor factor they said BLUE because of the aluminium head
dapinky wrote:Oh, come on Chris.........
This thread is about HGF, NOT Antifreeze - if you'd read it properly (or done a search) you'd find
this one![]()
chris.t wrote:dapinky wrote:Oh, come on Chris.........
this one![]()
oops sorry m8, saw pictures of anti freeze bottles and thought "this thread seems to have gone a bit off topic - oh well"
GeoffSmith wrote:Could people who have experienced HGF start a list of any relevant information to see if there is a trend anywhere?
Geoff
a5gcd wrote:After a run I noticed small coolant leaks either side of the radiator, it looked as though the radiator was leaking. Taking it off, the core was found to have "ballooned" due to over pressure.
rip wrote:So you've replaced your rad as well then?
L.G. wrote:Hi folks,
It maybe a pretty stupid question but is the head gasket a big job? (I believe it's a big YES)
The thing is I had the radiator and several other bits changed last year, as some may remember, because of a rust issue in the cooling system similar to rip's EE. I can see water coming from the exhaust when the car is running, I lose coolant little by little and the coolant smells a bit funny; I think. So I believe I have the symptoms. I'll have the cambelt change done in a month; so the question is, is it worth doing the head gasket as well?
I also don't know much about head skimming, is it required when changing the gasket?
Thanks,
L.G.
dapinky wrote:There's a 'Beck-Arnley' water pump on flea bay at the moment - not sure what it's up to though.
a5gcd wrote:If you are having all this done I would consider the water pump and the cam belt idler & tensioner. All available at a very good price from RockAuto.
