Head gasket failures - why so many?
Postby L.G. » Sun 13.04.2008, 22:26
I've just remembered a question I had in mind, is it worth buying the "head gasket set"? Or is that for rebuilding the engine?
'95 S2 driver #286
L.G.
Postby Monty » Sun 13.04.2008, 22:51
L.G. wrote:I've just remembered a question I had in mind, is it worth buying the "head gasket set"? Or is that for rebuilding the engine?
Yep it`s worth getting but it`s not a full engine kit, if you do have the head skimmed then you may need the manifold gaskets which are in the kit.
Postby L.G. » Tue 15.04.2008, 00:16
Cheers Monty, thanks for that info.
L.G.
'95 S2 driver #286
L.G.
Postby Stef » Wed 16.04.2008, 11:42
Blipi had her Head Gasket changed around 3 years ago.
She also has a lot of dirt that collects in the cap. Not oily stuff but from pipes/engine etc. Flushed her out and stuff and things seem better now. Was told I had nothing to worry about as dirt build up can be common.
A suggested HGF contribution I got given was the chip. Higher boost/more strain etc. But considering Blipi was around 15 with near to 100k on the clock I think age and wear had a big part to play.
She also had a tendency to use coolant, still does a little.
Well there is my contribution to a thread about engines! Who'd have beleived it eh?! :roll:
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby Paul.P » Wed 16.04.2008, 18:25
Stef wrote:Well there is my contribution to a thread about engines! Who'd have beleived it eh?! :roll:
I'm amazed at some of your new talents Stef, especially being a founder member of the EM crew, just shows you , you never know :wink:
Postby dapinky » Wed 16.04.2008, 18:33
It could be worse..........
I think i'll fall over when Gary adds to this thread :D
Postby rip » Thu 17.04.2008, 08:49
dapinky wrote:I think i'll fall over when Gary adds to this thread :D
He'll need to find out where his engine is first :lol:
Postby davidjt » Fri 18.04.2008, 00:14
LG - you probably won't need to have the head skimmed - but if you do and it's going to be stripped down anyway, new valve oil seals are a good idea.
(As usual, much cheaper from RockAuto than Lotus (£100!!)
Suspect skimming became popular on the basis of 'any excuse to up the compression ratio, however slightly', but if I remember correctly, that doesn't apply to turbo-charged engines - so if the head isn't warped or pitted it's not advisable. No doubt I'll be corrected if I'm wrong.
davidjt
Postby Stef » Fri 18.04.2008, 13:47
Us East Midlandsers need to throw the odd surprise, keep people on their toes. It's good to be able to get back on LEC again as I know many have missed my intellectual comments :wink: :-D
Stef
Postby Dave Eds » Fri 18.04.2008, 14:28
Stef wrote: as I know many have missed my intellectual comments :wink: :-D
and still are :smt043
new head gasket
Postby stonefish » Thu 24.04.2008, 17:52
hi,
anybody know suplier of uprated head gaskets to fit as i have gone through 2 in 4 months....not cheap !!! running extra boost but not enough to blow he head gasket i think...
jeff
stonefish
Re: new head gasket
Postby rip » Fri 25.04.2008, 06:39
stonefish wrote:hi,
jeff
Are you sure the gasket is at fault? If you have another problem (like a pitted or warped head, or the gasket has not been fitted well), then this will put extra stess on the gasket, forcing it to fail prematurely.
Head Gasket
Postby CStew » Tue 29.04.2008, 02:55
You could try a copper head gasket which can be custom made in different thicknesses to allow for metal removed in planing the head surface. I was quoted $65 not too long ago. Beyond that you could switch your head bolts for ARP studs that would allow higher torque on the nuts.
a driver not a garage queen
CStew
Re: new head gasket
Postby Paul.P » Tue 29.04.2008, 07:35
stonefish wrote:hi,
jeff
Jeff, extra boost or not ( unless its over 1 bar ) shouldn't keep blowing the head gaskets, lots of people on here running everest chips & been running BBR for years with no problems, so something else must be causing probs ?
Postby Enright » Thu 01.05.2008, 22:05
Sounds to me like either the gasket faces weren't properly cleaned the first time, or the head wasn't checked for straightness and needs to be skimmed.
Re: new head gasket
Postby Rambo » Fri 02.05.2008, 07:27
stonefish wrote: 2 in 4 months....
They must have been fitted incorrectly or there is another serious, underlying problem. I tend agree with what RIP and Neil have already said. Has the head been skimmed and were all surfaces clean?
Monty is a bit of a H/G expert and has done 2-3 (??) on Pinky but at least one (??) was attributable to an incorrect gasket being used and, from memory, one of the others was attributable to not re-torquing the head bolts after 500 miles
Postby Monty » Fri 02.05.2008, 12:18
Pinky II
1st HGF one was the original, so not bad for 17 years
replaced with a Kmckmc HG (none Lotus) and head bolts came loose whilst on track :roll:
Had the head pressure tested and skimmed, used the lotus HG this time and that lasted a few trackdays but this failed near the No1 cylinder to the water way :twisted: i can only assume that there was a bit crap that got between the gasket and caused it to fail :?
So that means i`m now on my 3rd HG change and this last one has been good up to now. If it fals again the i may need the Block skimming :shock:
This all happened in 2007 and which i did 9 trackdays in the Pinky bomb :-D
HGF
Postby CStew » Fri 02.05.2008, 14:43
Hussey Copper is the company that makes performance head gaskets especialy for turbo, supercharge and nitrous engines. You can see them at IPP (import performance parts) but the best price can be had by contacting them directly. ARP fasteners are much higher quality than original and can be had from www.robietherobot.com. The trend in tightning engine bolts has gone from torque wrench to stretch length using a dial indicator. I've read some about it in the ARP web site but not sure I understand. Does anyone know about this?
CStew
Postby Candles » Fri 02.05.2008, 16:11
Torque on the nut doesn't necessarily equate to pull on the cylinder head owing to differing frictions between the threads and mating faces of the bolts concerned. A stretch measurement gives a very accurate figure for pull down on the cylinder head as the bolt obeys Hooke's law.
Candles.
Candles
Postby Ekapol » Fri 02.05.2008, 16:25
Monty wrote:Pinky II
L.G. wrote: is it worth buying the "head gasket set"? Or is that for rebuilding the engine?
Watch out guys!! I've just had the 2nd HG job done after replacing the 1st (17 years) only 1 month. The 17 years HG came off in one piece VS 1 month old came off in pieces, and I wasn't even pushing.
I don't know where my conversion set came from, since I got them with the car, the previous owner must have bought them aftermarket. I'm sure he doesn't know how good they are. Comparing the OEM HG and the aftermarket just by eye-balling them and you can see HUGE difference in quality. Certainly 1 month is not a long life for them. :evil:
Stick with your OEM parts when it comes for your HG please.
Ekapol
Return to Engine
