by stevo » Sat 10.05.2008, 16:57
i fix one problem and 2 more arrive, you would think i'd be used to it by now.
the central locking will not unlock the drivers door, it opens the pas. side and will push the interior lock button half way up. lock sounds ok but is just stuck! how will i get it open?
stevo
by RayD » Sat 10.05.2008, 17:13
Stevo,
Do a few more tests to narrow it down.
Lifting both door latches - operating both door locks with the key - and see what works and what doesn't.
Will the remote, lock the doors when unlocked? and so on.
Ray
RayD
- Forum Member
by stevo » Sat 10.05.2008, 18:07
yeah mate iv,e been through it all. i have opened the door card a bit to try and get access but no luck.
oh and i don't have door lock barrels, i took them off during the respray.
stevo
by stevieshag » Sat 10.05.2008, 20:01
Maybe try some Chai stevo
black lotus elan se (kermit)
Mitsibushi outlander
suzuki gsx 750 W (Gonzo)
stevieshag
by stevo » Sat 10.05.2008, 22:22
stevieshag wrote:Maybe try some Chai stevo
you mean kicking the s**t out of it?
i've tryed that too
stevo
by Candles » Sun 11.05.2008, 07:26
Either a simple case of something sticking or it could be that the module in the door is dead. I'd do the following:
1) Remove lock button via orange clip trick. Wiggle wire to assess mechanism. If sticky, get in there with spray grease, WD40 etc and free.
2) If no joy with 1, remove door liner (
) and have a proper look. I have mine apart if you need any pics of where things are.
Candles.
Candles
by stevo » Wed 04.06.2008, 15:21
still no joy with this. i,ve tryed to take the pass. door lock appart to see how it ticks but its locked its self shut too. now i have one door locked closed and one door locked open.
has anyone had these appart before?
stevo
by ailwyn » Wed 04.06.2008, 15:58
Stevo,
This sounds like a central locking issue if both doors have locked.
See if (and I don't know how you would do it) the locks can be hotwired so that you can pop the lock open - I guess it must be a case of applying 5v or 12v to the live wire going to the solenoid/actuator.
Ailwyn
ailwyn
- Forum Member
by theelanman » Thu 05.06.2008, 10:35
can you use the key???
ie...disconnect the battery and try the key.....
line both locks up the same and reconnect the battery and see what happens
by GeoffSmith » Thu 05.06.2008, 13:24
The motors are controlled by the CDL - the circuit's on the
Wiki but It's not obvious what it's doing. As well as the CDL module (
behind the dash) the alarm is also connected to the motors, so it may be worth looking at the CDL and alarm.
- Kitty Fiddler
Return to Doors and Windows
