bu double g rrrrrrrrr
The parts arrived this morning and although they are a Dorman part and do fit the calipers the pins are NOT ally
The ones that algirdas got were alloy but they look like they are £18.00 a side which makes them rather mor expensive than the Dorman option
http://www.napaonline.com/masterpages/N ... Kit+-+Rear
It was fortunate that I ordered just the one as you lot would have been more disapointed than you probably are.
Will re investigate getting them machined.
I have take the view that I can either use a friends lathe (builds race cars at home) or I can purchase one my self
The latter may be a the way to go as I have the hub conversion to do and the prices I had for that have been higher than I would have expected
Material cost for the pins is small and the cost is really how long it takes to machine (not long once set up)
Will try to get 8 machined up asap care of a friend of mine and anodised as I know Geoffsmith is after a set urgently
As a note the the seals in the kits seem to be correct even if the pins are not
GeoffSmith you have a PM
