Got a call from LGM, again that she's away from her PC busy flying around
Can't believe we are doing this but here we go~
I see that we started to have few group-buys on the other thread, so I start this one for tracking turbo kit group-buy.
It was because of Nige that I decided to do this little inquire.
2 kits Im looking at, just for clarification.
#1 downpipe (turbo to exhaust flangepoint)
OIl feed line to turbo ( outlet is modified from stock piece)
2 coolant lines and addapter fittings
#2 all above +
Turbo inlet in either 2.25" or 3" (your choice)
Turbo compressor outlet in 2"
Turbo compressor discharch to intercooler pipe and silicone connectors
Turbo heat sheild (custom made)
with #2 all you will need to source is the turbo and adapter plate. I leave the intake pipe out as there are many different options as to what you can do such as there are too many options as to finished product.
Factory turbo on the right. Left one is much bigger with ball bearing
Downpipe
Without heatshield
The price for #2, everything you need, custom downpipe, sans turbo, CA tax 8.75% included, is $1052
The downpipe could be jetted hot for $60 or you could do it locally.
The Turbo, Garrett GT2560R, is $850 plus CA tax 8.75% = $924.38. LGM hand-polished hers and mine, which took her a day and a half for each I don't know if she would have time doing that but let me know if you want the polished version, I might ask Garrett if they could do that for us.
The whole set total is $1976.38 (GT2560R, AN Fittings, AQP hoses, Braided Stainless Steel lines, downpipe, custom made heatshield)
Please update the list below as you see suitable. We'd like to set the deadline for the list on July 5th. Then we will start collecting money and proceed with ordering them. I don't think we would do another run of this
ps: The above kit would work with Garrett GT2554 as well, since they both use the same frame, but I would stick with GT2560R
1. Ailwyn #2 everything inc turbo, 2.25", black connectors
2. Ailwyn #2 no turbo (I may change my mind based on group buy cost), 2.25", black connectors
3. Monty #2 (everything) 2.25" inlet, Blue Connectors.
4. MattDon (everything) 2.25", red connectors
5. Nige - #2 (everything), 2.25" inlet, Red Connectors. But dont believe I actually need the trash can to turbo inlet pipe or the connectors at either end of it. I will however go for the whole kit if that keeps things simple.
6. Paul.P -#2 ( everything ), 2.25" inlet, Black connectors.
7. Dico - #2 (everything) 3" inlet (I think), Blue Connectors.
8. dapinky - #2 (everything) 2.25", black connectors
9. F1 LOTUS - everything except trashcan > compressor inlet. (Red)
10. Richard K -#2 (everything), 2.25" inlet, Black Connectors
11. theelanman -#2 (everything incl turbo), 2.25" inlet, Yellow Connectors
Yes, I have the thing for fisheye lenses
